Generator electrical question
Started by Danny, June 10, 2018, 10:38:21 AM
Danny
I've got my Onan 7KW gas generator installed.  It works fine for one AC - but when I turn on the second AC it shuts down.  Any ideas?  As always, thanks for the help !!
I have heard it said, "life comes at you fast".  I didn't know it would be in the shape of a bus  :-)
richard5933
Do the a/c units work ok on shore power?
Are they both being powered by one leg of the generator?
Melbo
Do you have a clamp on ammeter?  Check the draw with one then the other ( watch for the peak as it fires up ) and you might answer your own question.
Just a thought.
HTH
Melbo
Dave5Cs
Start one and let it run for a few minutes then turn on the second one and see if it is works.
I am not a fan of splitting smaller generators into 120/240, if yours is.
Otherwise, you only have a 3500 watt generator, twice, which starts limiting the reality of what will start/run.
And, I have seen them wired wrong, and 3500 is all you have, period.
Under the cover, most have the schematic for which way to hook up the 4 wires to achieve either configuration.
Balanced loading is your goal, if wired for 120/240, very hard to achieve a close percentage, at these low loads.
Happy coaching!
Buswarrior
Danny
neoneddy
Make sure to add soft start capacitors, most RV shops have them for $25-$30 and they are easy to install.
Raising hell in Elk River, MN
1982 MCI MC9
6V92 / 4 Speed Auto (HT740) Video Build Log - Bus Conversion & RV Solar company we now started thanks to our Bus
Danny
