Theft Deterrent
Theft Deterrent
Started by DominicM, June 07, 2018, 08:18:55 PM
DominicM
Im not sure why he felt the need to park the bus on the rotors to keep someone from stealing them, they didn't look to be a good set anyhow.  Each front tire was holding down a a pair,  they must be valuable rotors.
I wonder if he placed some coal in between the rotors and hoping the bus would create enough pressure to convert the coal into a diamond?
Just trying to stimulate some clever thought exchange.  By the way this was in front of a steel fabrication shop, it is a Provost, rotors are being used to level the bus. Not sure I would have chosen this method, I would prefer a larger foot print, maybe rotors from a larger truck rather than from a geo metro. ha, ha
67 MCI 5A
I live in Nashville,  and Reside in my 5A in Big Spring TX for work at the moment,  Will update as I move around.
windtrader
If he told you that is reason for bus sitting on rotors, go back and ask him directly? Makes absolutely no sense as a deterrent unless maybe the bus is on blocks all around, so a jack is needed to drive it off.
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
His crude version of flatstoppers maybe to prevent the tire from flat spotting
Iceni John
They had received some Chinese rotors that weren't perfectly flat.   The instructions (in Chinglish) said "The rotors should be flat, bus in case they are not you must apply steady pressure to them."   It's amazing what can happen from one simple typo.
2kW of tiltable solar.
Iceni John
Maybe it's an Eagle, and they're its sacrificial anodes to stop it rusting.   Sorry, Gary.
lol that is not a Eagle with those funky rubber fender flairs
A Prevost not a MCI,lol you need to lighten up on Eagles they are good buses and don't use suspenders holding the engine up
Gary Hatt - Publisher BCM
Funny you should post this.  This is where I hide my keys.  ;D
1999 Prevost H3-45
windtrader
Ah, maybe Eagles are too good to have their feet touching the ground while not turning. Did not catch these were a coach pedestal. You know them Eagle owners, just look up to catch a view of their noses.
Don F
Fully converted
Bought 2017
Only the Prevost owners do that, although they use a good quality Berber carpet.
Utahclaimjumper
 Looks to me like a leveling method.>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
Dave5Cs
Those are not rotors they are actually vented Land Mines. Do not move that Bus, ::) :o
