Blowing tranny fluid all over.
Started by Scott & Heather, June 03, 2018, 06:37:18 PM
Quote from: Scott & Heather on June 05, 2018, 05:25:58 PM
Other hose is fine for now. Hose wore through at a retaining clamp. Silly design. I removed the clamp.
New hose is pretty:
WOW...$50.00 a foot, that's thievery in the nth degreee..for low pressure 2wire   ??? ??? ??? ...
OMg :(
We'll cross our fingers for you.
windtrader
Well, that is a hell of a hose. Reminds one a bus is NOT a car. lol
Glad you got going again Scott. Hope losing the 4 gals of transmission fluid did not damage the tranny.  It does make you wonder though if the seals or other internal parts got roughed up.
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
That may be an expensive hose, but it looks nice. Larger diameter fittings start to get costly. Big money in that business. Plus, imagine the inventory costs carrying all the different fittings, hoses in different pressure ratings in different sizes.......Good that he was able to get it right away.
David Anderson
Scott,
I had the same thing happen to me in 2010.  I was able to fix mine on the road and scoot home.
http://www.busconversions.com/bbs/index.php?topic=17011.0
Glad you got it fixed
David
Quote from: chessie4905 on June 06, 2018, 05:04:23 AM
Parker hose are expensive but good hoses not the cheap made in China stuff, my local hose shop offers me 3 different grades and Parker is always around 30% higher than the others and I go with Parker
If it's a critical application, go with the best.
Iceni John
Quote from: David Anderson on June 06, 2018, 07:05:25 AM
Scott,
David
And coincidentally last night, while I was under the bus staring up at nothing much in particular (I spend a lot of my life doing that), I saw a few hoses that crossed others which weren't secured to prevent movement.   So, a few zipties later I felt that I had done something useful with my life  -  zipties are cheaper than replacing worn-through and chafed hoses.   At this rate my bus will soon be more ziptie than bus.   Better safe than sorry.
Yup, good hose ain't cheap.   It's mostly Parker or Aeroquip for me, but I've also used some of Eaton's Seltex R4 hose made by SEL in Turkey that seems OK.   No Chinese hose for me.
2kW of tiltable solar.
Iceni John
Scott,
David
David, you mentioned in your original thread about adding a pressure warning switch to the tranny, to alert you to problems such as the leak you had.   Did you ever do this?   If so, where did you put it?   Don't HT740s have some spare ports that could, maybe, be used for this?   I like the idea of adding a low-pressure switch, but I don't know where would be best.
Low level in the pan is better the 740's will have pressure to the very end
No more leaks. Topped off fluid. Will drive coach 200 miles on Sunday....will report back.
The Allison brochure mentions low fluid level sensors available for either a light or buzzer.
Transmission is going to tell you there has been a catastrophic leak, as Scott had, by reduced functionality. It either has juice and goes, or it doesn't.
The driver will find a seeping leak by circle check, dipstick check, puddle, mess in engine room and wearing tranny oil on the rear of the coach and toad.
If a warning device was critical to transmission destruction,  you'd have one already...
And, zip ties cut hoses. Use the proper rubber lined hose clamping hardware if there is motion present!!!
Happy coaching!
Buswarrior
Quote from: buswarrior on June 07, 2018, 08:32:04 AM
Happy coaching!
Buswarrior
A temperature gauge on the transmission will tell you,when a Allison get out of it's safety zone from being low of fluid the gauge will climb
Yes, tranny temp is a worthy busnut item.
Some coaches have poor tranny cooling, degraded heat exchangers, previous owners obstructive parts changing, etc.
Cool tranny lives a long life,hot tranny lives a shorter life.
Again, I would hope a busnut discovers and manages a seeping transmission via engaged visual inspection, long before any mechanical measuring device indicates a problem.
A burst leak, to the side of the road you will go, lack of forward motion happening concurrent with any accessory warning devices alerting the driver.
Happy coaching!
Buswarrior
