8V71 serial number
Started by Astro, May 02, 2018, 10:06:38 PM
Astro
How common is it to not have a serial number on a DD8V71?  I have searched all the noted spots on my motor and have not found a single digit.  I have an option to pick up a spare 8v71 for almost nothing but the work.  I was hoping to get some build data on mine through the serial number but there is none to be found.  What do I need to know to see if the option engine will work for me and my MC5B? Thanks
Ken
Arlington, WA
1971 MC-5B, U7017, S9226 (On the road)
1945 Flxible Clipper (In conversion)
1945 Flxible Clipper town buggy
Built from scratch with a new bare block?
I wouldn't put too much stock in the serial number at this point. It tells you how it started life, but once in the hands of crafty re-builders, it can be all re-configured.
Perhaps Brian Evans will chime in, an MC5 owner who re-configured a military engine for bus use?
Happy coaching!
Buswarrior
Geoff
When I worked for DDA, the replacement blocks came without numbers.  So it is not unusual to find no numbers.
Geoff
'82 RTS AZ
MCI is a little different on the rear if the engine didn't come from a MCI it takes a lot of work to change the rear plate, drives and bell housing,I am getting ready to change a industrial 8v71 to the MCI set up and not looking forward to it
