102A3 air bags
102A3 air bags
Started by dj, January 18, 2018, 04:56:33 PM
dj
Hey does anyone know where I can get part numbers for the steer and tag axel air bags for a 1988 102A3?     thanks
Dave5Cs
Out of a part book for your model or call MCI, Call Luke in NJ US coach. Or maybe someone on here that has your model will answer you here.
dj
I don't have a parts book handy and calling MCI didn't help all their "books" are being moved for some reason so that wasn't any help.....do you have any phone numbers I could get to get some part numbers Im going to order them through my Petebilt dealer  (big discount been dealing with them for years)...just need some part numbers for either goodyear or firestone bags steer and take Ive already changed the drive axel bags   Thanks for the help
Dave5Cs
Call Luke in NJ us coach, 888-262-2434
Go here and you can find your part manual and other ones. ;D
http://www.coachinfo.com/Coach_Manuals/MCI/MCI-102A.html
I wouldn't call Luke if you don't have any intention of buying the airbags from him, but just looking for info. He is a great resource for us and has supplied our needs for many years, but is not in business to be only an information resource. How about the Facebook bus conversion forum? Best bet is to get the manuals, as you'll be referring to them as long as you have the coach.
jdpilot
Hello DJ, Send me your email address to jdpilot@hotmail.com and I will send you a PDF with the Info.
There you go...what this forum excells at.
FWIW Luke not only had all of my air bags in stock, he also had the fasteners and was significantly cheaper than any local source I could find.  Kind of removes the need to do a lot of shopping around, in my opinion.
Ditto bevans comments.
Home Despot doesn't know diddle about a fine thread 1/2 inch nut.
Order from Luke, if you have read the boards, you've already received his help, either directly or re-stated by someone else.
jmblake
I got mine from Luke also, Highly recommend him, Prices are good and fast shipping. BTW I had the part #s and none of the local truck places could get them they were exclusive to a MCI.
Jason
Dave5Cs
Why I told him because you won't get all the parts you need at a truck shop. Special bolts you will need and you can even get them all put together from him so all you have to do is take out the old clean it all up and put in the new ones, test for leaks done. The bolts will be rusted and you will have to cut a few or all sometimes with a dremel or nut cutter. Soak with Kroil and hope etc. ;D Just saying
dj
hey thanks for the info   Ill give luke a call .... replies are greatly appreciated
dj
And I did order a PDF parts and operators manuals
