MCI 5 Ride Height
MCI 5 Ride Height
Started by Lifes2short4nofun, January 06, 2018, 05:16:01 PM
Lifes2short4nofun
We read the book and it seems we have the ride height adjusted right underneath but it doesn't look like it when I look at the tire clearance for the front.
The back looks right I think.
Can any of you give advise?
1972 MCI 5B
Astro
Looks pretty decent to me. With the rubber skirt up front, it throws off the look compared to back. Mine looks the same and rides level.
Ken
Arlington, WA
1971 MC-5B, U7017, S9226 (On the road)
1945 Flxible Clipper (In conversion)
1945 Flxible Clipper town buggy
Ride height should be level with the top of the bottom step in the doorway 14" above the ground.
At least that's what my 5C's books tell me, I'm guessing there's not a lot of difference between the B and C suspension settings.
Looks like mine, even though a GMC.
Utahclaimjumper
If not somewhere close the U joints on the drive shaft will suffer.>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
As noted, you have different wheel well treatments, which screw up "the look"
If it measures correctly, job is done, what it looks like matters not...
Also as noted, proper measured ride height is important for u-joint driveshaft angles, and suspension/steering geometry.
