Bay Door Adjustment on a Prevost XL
Started by bigred, November 18, 2017, 04:24:21 PM
bigred
Saw where Richard asked for this info for his 4108.Some of the bay doors on my Prevy are leaking bad.Is there any thing I need to know before I tackle adjusting These things ???
Gerry H
Hello Big Red: I put all new luggage bay door gaskets on my 92. bought them from Prevost. Don't know about adjusting, but mine were all deteriorated. They are self stick or I used some 3m weather stripping adhesive from NAPA. Also replaced my entry door gasket while at it. Gerry H
Forest Lake, Minnesota
Land of 10,000 mosquitoes and a few cool buses
bigred
Thanks Gerry .I may need to do the same thing.Thing is the gaskets look good on mine ,but the latches will lack the bin doors with hardly any resistance which makes me think they may need adjusting .F DS is the worst one.
robertglines1
loosen catch on lock mechanism move toward center of coach. tighten. Try-this should make door not only lock better but pull doors to seal. Get it to tight just back off. two per door.
I have a set of bay doors and engine compartment from a Xll with the stainless rub rails if you guys ever bang up a door lol I need them gone.I have the complete coach control panel from a Country Coach Prevost if anybody needs one also
bigred
Quote from: luvrbus on November 20, 2017, 07:15:36 AM
Cliff : Do you per chance have the CC lighting control board ? This is the one that is in the lower compartment under the drivers seat.One of those little relays has burned to a cinder and has blackened the board .All the lights are working ,but cant turn the lighted switches off !!
