Door opening
Door opening
Started by rwc, October 11, 2017, 12:02:18 PM
rwc
MCI102D3 has been sitting because of health problems. Got it started and it runs fine but door will not open and close using air. Moves fine by hand but push button to close door and nothing happens. What do I need to check??
thomasinnv
Just below the right side of the dash is a little lever with a red ball on the end, make sure it is pulled all the way out. That is the door air release lever.
Sent from my SM-G920T using Tapatalk
1998 MCI 102-DL3
Series 60 12.7/Alison B500
rwc
sledhead
plus inside the electrical panel under the drivers window there is a pull cable to manually open the door and some times it gets out of adjustment
can't remember if it should be in or out
dave
dave , karen
rwc
Will check that also Thanks
Zephod
Quote from: thomasinnv on October 11, 2017, 12:56:59 PM
This is the emergency door release. It could also be above the door.
B_K
Quote from: Zephod
NOT ON AN MCI!
That is the release for the air cylinder under the dash. And yes the little red knob on top of the door on that model MCI is the secondary latch/release but the knob over the door has NOTHING to do with while the air cylinder is not working, it is 100% the little 2" lever w/red knob under the dash that releases air to the cylinder on an MCI.
:D  BK  :D
rwc
The knob above the door is a secondary latch that activates when in gear.
