Broke Down! Need help with Allison MT 647
Started by oldmansax, August 17, 2017, 01:12:47 PM
oldmansax
I have an Allison MT 647 Mechanical behind a 3208 Cat. It has been shifting fine. I drove it about an hour and a half this morning to a campground. It did not want to shift into 1st when I stopped to check in. I revved it up a little and got to the campsite. Now it won't shift in to 1st at all. It shifts into reverse fine. I did notice the trans temp ran about 245 which was higher (I think it has been running about 220 but it is hot here today) than it has been. The fluid is on the full mark. It SEEMS to smell a little burnt but not much and that may be my imagination. I'm getting paranoid!
Any suggestions? Ideas?
Thanks!
TOM
1995 Wanderlodge WB40 current
1985 Wanderlodge PT36
1990 Holiday Rambler
1982 Wanderlodge PT40
1972 MCI MC7
ol713
  Hi;
     Can you tell us what part of the country you are in?   Maybe help is close by.
                                                 Merle.
oldmansax
Eastern Shore of Virginia. Little town called Temparenceville.  There are aurthorised Allison shops in Salisbury, MD which is not that far away but I am hoping I can drive and not have to be towed.
Also, cell service  is awful. I can get texts but that seems to be all.
four four three 52 won seven seven 6 ate
TOM
1972 MCI MC7
You have low main pressure Tom ? do you know how to check the pressure by removing the plug and installing a gauge
oldmansax
Clifford, no I don't and I only have minimal tools with me. I haven't had any mechanical troubles with this coach and was only going a couple hundred miles so I thought I could get away without a bunch of tools. That's what I get for thinking! I don't have a gauge either. However, would I still have good reverse with low pressure?
TOM
1972 MCI MC7
oldmansax
Thanks for the info!
Any thing I can do about it to limp home? If I rev engine is it possible to get it to shift to 2nd without major problems. If I have to go into the trans, it will have to either drive to my shop about 50 miles or be towed. If I have to get it towed I just as well call them tomorrow morning.
TOM
1972 MCI MC7
oldmansax
FYI, flat ground all the way. Need to at least get out of the campground. It will be a nightmare getting a wrecker in here.
TOM
1972 MCI MC7
Zephod
oldmansax
Quote from: Zephod on August 17, 2017, 06:44:57 PM
http://allisonparts.net/Allison-Transmission-Parts-Tips.html
That might help
Thanks for the link!  I guess I will just see If I can get it to move tomorrow morning. Hopefully I can get it somewhere to rebuild the valve body if that is the problem. I'm still hoping for a temporary magic fix!  LOL!
1972 MCI MC7
I hope it is a easy fix too Tom but the smell of burnt oil is not a good sign,245 is a little warm they run between 180 and 220.They can tell in few minutes with a pressure test where the problem is.If I was closer I would help you and it would only cost you crab-cakes :o
Lin
when was the last time the filters and oil were changed?
oldmansax
Quote from: luvrbus on August 17, 2017, 09:08:42 PM
I know you would help if you were closer and I not only appreciate that but all the help you (and the rest of the guys on here) have been. If you were closer I would buy the crabs cakes anyway....help or no.  LOL! Once I get to the shop I will get the manual and pressure test it. I just didn't think I was gonna need hard core tools for a short run. :(
Last question (maybe): It never did stop moving completely, meaning I can rev it up and move in 1st. Any chance I can get it going fast enough to shift into 2nd? Maybe get back to my shop (50 miles)?
Lin: Supposedly all fluids and filters were changed when I bought it. I have put less than 5000 miles on it. I was gonna change it anyway this fall when I do seasonal maintenance. Would filters cause this?
Thanks!!!!
TOM
1972 MCI MC7
Branderson
I'm curious about the burnt smell of fluid.  Does that normally only mean burnt fluid b/c it got too hot or does it typically mean a catastrophic break down of the transmission.
- Brad
thomasinnv
Quote from: Branderson on August 18, 2017, 06:17:44 AM
It has been my experience that once you see/smell burnt fluid it is usually too late. Damage done.
Was it just a faint hint of a burnt smell? Or was it a strong obvious odor and color? With only 5k on the oil and filter and being burnt would not give me a positive feeling, especially with the high temps.
Sent from my SM-G920T using Tapatalk
1998 MCI 102-DL3
Series 60 12.7/Alison B500
