Radiator sight glass
Started by bigred, August 05, 2017, 02:24:37 PM
bigred
I know this has been covered be fore ,but I'll be danged if I can find it. Where does the anti freeze need to be on the sight glass?? I/2 way up.1/4 way up 3/4 way up or should the sight glass be completely  covered??? Yes I know !! Another  amateur question!!
Completely covered as long as it is in the sight glass the level is safe
bigred
MagnoliaBus
Denis, North of Montreal, 1989 Prevost XL40, 8V92TA HT740
I like to have the cold level right in the middle of the sight glass, so I can see the line so I don't get fooled by thinking I am looking at coolant instead of air.  It will usually go up above that when hot.
Iceni John
I deliberately overfilled my surge tank, drove until the coolant had expanded and come out of the overflow tube into my catch bottle, then after it had completely cooled down I marked the level on the sight gauge as the maximum cold fill level.   Easy!
2kW of tiltable solar.
muldoonman
Fill my tank up and let it overflow to where it wants to run. Has worked for 7 years so far.
All the Prevost books tells you about the sight glass is " if coolant is visible when cold it's good.All the Prevost people I know keep the glass covered
