A couple quick questions before I drive my MCI for the first time in a while
Started by Oregonconversion, July 13, 2017, 09:07:49 AM
Oregonconversion
 What type of oil do I put in the  blower gearbox?
How do I check my coolant?  Also what type of coolant do I use?
  Outside on the front drivers side there is a compartment ( hello fuse panel compartment ) with a  plastic  reservoir with some type of oil. Is that power steering and if so what type of oil does it take?
Thanks in advance taking off in a couple hours
1977 MC8
8V92 HT740
Oregonconversion
 42 views and no one can help me out? Need some help here I'm afraid my power steering will go out if I don't put in the correct oil in it
I figured out the oil for the blower fan
1977 MC8
8V92 HT740
Oregonconversion
 I just really need to know what is in the reservoir next to the airhorn? It's a  plastic bottle with some type of black fluid in it.  Has rubber hoses coming in and out
1977 MC8
8V92 HT740
On my bus, that is the windshield washer fluid container.  The power steering reservoir is on the back of the engine near the compressor, directly above the power steering pump.  I have no other plastic container on the bus.  Coolant level is on the sight glass on the expansion tank up above the fan blower box, coolant fill is behind a little door on the upper passenger side rear panel (above the radiator).  I use normal green antifreeze.
plyonsMC9
On my MC9 - for the blower gearbox
Blower Oil ( per MCI9 Manual: SAE 30 )    Between the two squirrel cages - there is the sight glass.  Again using my MC9 as a reference.
As Brian said, the plastic bottle on my bus is for windshield fluid.
Hope this helps, Phil
plyonsMC9
For antifreeze I use the pink - Fleetguard, or red if non-diluted.
We have pretty rough well water, so I mix the undiluted with distilled water.
Something like this:
https://www.amazon.com/Shell-Rotella-Ultra-Antifreeze-Coolant-Ready/dp/B072JKTQM1/ref=sr_1_2?s=dmusic&ie=UTF8&qid=1499973153&sr=8-2&keywords=rotella+antifreeze
per the book I think this is recommended.   YMMV..
Branderson
Quote from: bevans6 on July 13, 2017, 11:04:59 AM
That is where my steering reservoir is also (on my 74 MCI)  I put antifreeze/water on the little opening on passenger side towards the top.  I need a latter to reach it.  Basically it's above and to the left of the tag axle.
- Brad
Branderson
I can't remember what type of oil to use for power steering.  But I have it written down on my bus.  If no one answers by the time I get off work, I will stop by storage and see what I wrote down and post it.
- Brad
You can use SAE 30 engine oil, or about any variant thereof, for power steering fluid, or transmission fluid.  I think I used 10W-30 engine oil.
plyonsMC9
Missed the power steering question;  again referencing my MC9 :
per MCI9 Manual: 10 W 40
hope this helps, Phil
ol713
Quote from: Oregonconversion on July 13, 2017, 10:37:40 AM
        Hi;
          I am pretty sure that reservoir used to hold washer fluid for the wind shield.  That
          is what it was for om my MC-7.    (close enough)
                                                  Merle.
ol713
    Hi again;
         How far are you going on your "first drive"?  By now you should have all your
         questions answered.   Please post again if questions not fully answered.
                                                      Merle.   ;)
bigred
Napa has a heavy duty marine and diesel anti freeze it has all the additives in it for the Detroit engines that I use .If you have a good contact it will run you a little over thirteen dollars a gallon and about a buck for a gallon of distilled water.This works out to be two gallons.
And no response. The search feature is your friend. I recommend for sure that you spend a few days getting your bus mechanicals ready before your next trip...I know my bus inside and out intimately and I spend a day prepping it before trips and I drive it 20,000 miles a year. If you're this unfamiliar with it, asking the questions you asked above should happen days before your trip. Just my thoughts. Hope you got your questions answered.
PP
Quote from: Scott & Heather on July 13, 2017, 05:14:18 PM
Ditto
