Broke a bay door cable
Started by Tikvah, May 03, 2017, 03:57:32 PM
Tikvah
Where do I get a cable?  Just a hardware item?
Any tricks to changing it?
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
Gary Hatt - Publisher BCM
Dave, aircraft cable should work fine which you should be able to buy at a good hardware store. Of course, MCI probably has it in stock cut to length with ends on it too for a slighly phenominal fee.  I broke mine too but I never got around to changing it because it looked difficult to do with my water tank in the way so I left it for the new owner to fix.   ;D
1999 Prevost H3-45
PorchPeople
If you have the tools to fabricate a new cable it's very doable. Changed a few not long ago. We had the puller from a greyhound shop ( think tuning fork with 90deg bend and a handle) to pull the cable and then used vice grips to hold it while the end was attached. Be sure not to munch the pulleys and that they are aligned with the cable.
1966 MC5-A
8v71 Spicer 8844-A
Williams, CA
ol713
   Hi;
       I would find some one parting out your model coach.   You can usually get
       them for next to nothing. I got mine from a MC-8 some years ago, and
       got two or three while I was at it.  You only need a few tools and some
       vice grips to hold the cable.
                                      Good luck   Merle.   ::)
Geoff
Home Depot and Lowe's sells different size cables along with the fasteners.
--Geoff
Geoff
'82 RTS AZ
Frank @ TX
Hi,
It seems I have to change a cable about every other year.
I get them from Luke with the ends and the length correct.
Just use the old broken end to fish thru the new end.
Get it on the pulleys correctly and the tool I use is a claw hammer to pull it to the connection point.
It's not that hard to do and no new tools are needed.
Frank
Dave5Cs
If you have a manual it explains exactly how to do it.
The 102D coaches finally had a little chain and holder that wrapped around the opened pantograph at the pinch point, that secured the door in the upper position. Still requires the driver to actually use it...
For those that haven't been there YET, those doors are heavy, and quite capable of being a widow maker if they come down on you.
Has anyone built themselves a safety catch of some sort to defend against spring or holding feature failure?
windtrader
old broomsicks are cheap.  :P
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
MB LeMirage
My 1980 Prevost has holes drilled in the arms for safety pins to go in and they also have a large sprung metal tab that has to be pushed in in order to close the doors. It pops into place every time you open any bay door and blocks the hinge mechanism in the full open position. Both are simple and effective.
Ryan.
Ryan D.
1980 Prevost LeMirage
8v71n 6spd Manual
Ste Genevive M.B.
