Leaking Air Valve MC7
Started by Stormcloud, April 28, 2017, 10:11:31 AM
Stormcloud
This culprit is leaking air around the diaphragm. Pretty sure its the the regulator valve that controls the bellows pressure on the tag axle but its possible it's the brake relay valve. Before I order parts, I'd like a 2nd, 3rd, 4th opinion etc.
It is located beside the pivot for the throttle linkage at the bulkhead of this MC7.
Thanks in advance!
Mark
....and following further inspection, it is indeed the tag axle bellows regulator.
Mark Morgan
1972 MCI-7 'Papabus'
8v71N MT654 Automatic
thomasinnv
That is the air pressure regulator for the tag axle air bags. Get a replacement and set it to 35psi and you are good to go.
Sent from my SM-G920T using Tapatalk
1998 MCI 102-DL3
Series 60 12.7/Alison B500
Stormcloud
Yep, thanks for the confirmation, Derrick.
Luke at US Coach shipped one out to me on Friday.
Mark
Mark Morgan
biff
Mack sure you get a relieving type regulator. not a non relieving or it will put to much air into your airbags.
