OTR Heat Keep it or Remove it? What do you recommend for heat?
Started by neoneddy, April 27, 2017, 01:33:29 PM
neoneddy
We'll be using this mostly in the 3 seasons not Winter, but we hope to take some spring break trips as well.  So heat is a thing we'll want to have.
I've used the OTR heat and it works great.  I've thought of using Propane (I'm planning on having propane Range and 2 Way Fridge as well) and having that work in the ducting that is there.  Attached is the current state of the floor.
Raising hell in Elk River, MN
1982 MCI MC9
6V92 / 4 Speed Auto (HT740) Video Build Log - Bus Conversion & RV Solar company we now started thanks to our Bus
daddysgirl
If they kept the same design, the OTR heat runs off the engine system. You need that.
That said, if you remove the plywood that is now at grade with the ducts, you'll find a nasty dusty greasy...mess under that plywood. You'll want to clean it.
I still have my OTR system and I don't think I could survive in the summer without the OTR air. It is the only way to provide AC to the driver, and I have 3 roof units :)
Anyway, welcome! This is a great place for information and the folks here are the best.
Andrea   Richmond, VA
neoneddy
My OTR Air was removed by some previous owner.
I've thought of putting it back in there, but in talking with Grumpy, he said he'd do roof airs if he had it to do over again, but that was vs basement air I think, he has OTR air as well.
I was hoping to get away with 2 woof airs, I was going to tackle that in another post.   I've done a ton of research, but I have a list of about a dozen questions :-) . I'm just trying not to flood the board.
1982 MCI MC9
Quote from: neoneddy on April 27, 2017, 01:33:29 PM... So heat is a thing we'll want to have.   I've thought of using Propane ... and having that work in the ducting that is there.
    Can't talk about the state of your floor (if I did that, I'd be standing on concrete ... been there), but usually the biggest thing about a combo heat (or AC) system is unifying the two different parts of the system.  If you're going to keep vents and ducts, you'll probably want to keep the stock heat exchangers and fans for when you're moving down the road, but doing a bifurcated system with an add-on propane heater for when you're parked should work just fine.  I would want to have some kind of diverter or blend door so that the production of air from one source would be properly directed so as to not "bleed off" through the inactive unit ... but that's just me, I guess.
Quote from: daddysgirl on April 27, 2017, 01:58:43 PM... I still have my OTR system and I don't think I could survive in the summer without the OTR air. It is the only way to provide AC to the driver, and I have 3 roof units :)
    Again, you would have to have two different A/C systems.  That's also not fatal -- what has proven to be fatal for many people is having to spend thousands of $$$ over a couple of years trying to nurse a 30-year old OTR A/C system along and still have something that's not dependable -- yeah, many people.  If you can keep a OTR A/C going, that's good but I'd never depend on it.  (What you can depend on is that any unreliable system will crap out in the worst place at the worst time.)
    If I had three roof tops and couldn't keep the driver cool, I'd want to know what was wrong with them but maybe there are some buses and some conditions where three -- installed in the best place and with the best installation -- wouldn't be enough.  I dunno.
Quote from: daddysgirl on April 27, 2017, 01:58:43 PMAnyway, welcome! This is a great place for information and the folks here are the best.
Big agree on that.
Quote from: neoneddy on April 27, 2017, 04:17:12 PMMy OTR Air was removed by some previous owner.
      That ends that subject right there.  It would double your budget to replace it, that is, if you had a BIG budget, it would double it to replace it.
Quote from: neoneddy on April 27, 2017, 04:17:12 PMI was hoping to get away with 2 woof airs, I was going to tackle that in another post.   I've done a ton of research, but I have a list of about a dozen questions :-) . I'm just trying not to flood the board.
      What some people have done is put a regular car compressor on the engine, run piping to a receiver dryer, install a dash system for the driver and put 2-3 roof tops up ("technologically dense" as Mazda's rotary wizard used to say, and somewhat expensive, but it is the best way for some people.  Other people are in places where they need 4-5 roof tops when they're parked, and they work for the time they're on the road.  How do you run an A/C system?  Some people have enough juice out of a big oil-cooled alternator through an inverter, others run their gen set running down the road.
      As you can see, a lot depends on your bus (insulation, number/types of windows, layout of floor, size of windshield, amount of heat from engine and underfloor, amount of hot[or cold]-outside-air ingress, etc.).  You gotta figure out what you need and design a way to take care of that.
ol713
   HI;
       If your OTR heat is working, keep it!  You will need to do something
       else when parked.
                                      Merle
daddysgirl
Everything Bruce and Merle said...
BUT...pull out that top layer of plywood. You need to clean that channel regardless of your choice of heat. You will be surprised by what's there...but don't be. It will come out.
The reason my front AC doesn't cool the driver is the windshield and the insulation. The latter I am doing now, starting in the back. The former is what it is, although I will make a couple of modifications.
My OTR AC is wonderful...never failed me. It's been converted to 134A...but it will freeze me out when it's on. That said, I have been thinking of a smaller unit. I just haven't decided yet. I'm still tearing out and working in the rear  ::)
Andrea   Richmond, VA
Astro
Quote from: daddysgirl on April 28, 2017, 05:21:55 AM
The reason my front AC doesn't cool the driver is the windshield...
Andrea, You might look into newer window films and tinting product from XPEL (XR or CS) or others. They have a SPF of 1000 or so. I had all my 25 yo  window tint replaced with them and we noticed the difference in the Texas heat immediately. I also had the front windshield done and it really made a difference. It has only 5% shading, but still has the SPF 1000 protection.  Just a thought...
Ken
Arlington, WA
1971 MC-5B, U7017, S9226 (On the road)
1945 Flxible Clipper (In conversion)
1945 Flxible Clipper town buggy
daddysgirl
Quote from: Astro on April 28, 2017, 07:30:39 AM
Oh yes...I am planning on adding some sunscreen. I need to make sure I don't run afoul of VA law in the process. They are funny about that stuff here.
The year after dad passed, I took mom to a bluegrass festival in NC. 5.2 hours driving into the sun on the way home...with the world's worst hangover...and I don't get hangovers :) When we got home, I had actual tan lines all over the front. I couldn't believe it.
Andrea   Richmond, VA
Geoff
Quote from: daddysgirl on April 28, 2017, 08:34:00 AM
Tan lines.  The new window glass is UV resistant so you can't get tanned through the windshield anymore.  A downside to this is if you wear prescription glasses with auto-darkening they won't get dark.
As far as OTR heat, you must keep the copper lines going to the front for the defroster and driver's heat.  I don't know why it hasn't been mentioned yet, but a 45k btu Webasto diesel-fired heater can be plumbed into those existing heater lines and with some heater boxes integrated into the interior off those lines you have the best camping heating system.  You can also plumb for floor heat with the Webasto or Esbar heater.
--Geoff
Geoff
'82 RTS AZ
bigred
You need to remember that without OTR heat ,you will have to depend on a couple of small fans up front for your defrosting which will drive you nuts .On you AC units ,i can tell you that these roof mounts are not what the used to be .I had my three RM's replaced with three made in China Dometics and I can tell you ,these are a sorry excuse for AC units .WE haven ran them except while parked ,but I can't see these three units keeping this coach cool. Have two Colman's on a 22 year old motor home that cools way better than these dometics do.
lvmci
Hi Andrea, I  put 3 units on my 40'er, on the front unit in the living room, I put the AC closer to the driver,  then took 90 degree  aluminium  foil 1 1/2" ducts and attached them to the side vents of the drop down style AC, when I'm  driving the 15K unit is enough to keep me and her cool, I  run the center AC also, on days over 100°, but then I'm  from LV, so i might be more tolerant of heat, lvmci...
MCI 102C3 8V92, Allison HT740
Ed -
If your OTR heat works, keep it.
My OTR A/C doesn't work, and the two roof A/Cs can barely keep my 35' MCI cool on a 90o day
But the OTR heat keeps us toasty going down the road in temps down to below freezing, and, of course, the defroster works wonderfully.  It's especially nice on those cool mornings in the upper 40's - mid 50s to keep the chill off inside as the day warms up.
Geoff's comment is an excellent suggestion - best of both worlds! Engine heat going down the road, Webasto or Espar when parked.
bigred
Quote from: Geoff on April 28, 2017, 09:16:45 AM
--Geoff      They have glasses now that will get dark inside a vehicle .Got mine at Sam's,but I will say this .If you see a tunnel in your future you better lose these things in a hurry ,lol
daddysgirl
Quote from: lvmci on April 28, 2017, 01:27:58 PM
I have 3 units also, the front unit is just past the hump on the MC8...maybe 3-4 feet from the front. I started in the rear, but the front AC needs attention, and I'm tearing down the ceiling while I'm at it.
Question... Did you duct the front roof top air? or do you have an additional unit? My OTR is still fully functional, but I want to plan a backup now...while I've got her torn down. I could easily run 1 1/2" ducts on the ceiling...just looking for clarification :)
And BTW...I really appreciate your suggestions. Really...Thank you.
Geoff...
My windshields are in perfect shape. I can't justify replacing them, but I sure as heck can justify the most shading I can legally pull off :)
Andrea   Richmond, VA
