Claw Foot Bath Tub
Started by luvrbus, November 24, 2016, 10:02:15 AM
How many here have a claw foot tub in a bus and what options do you have.I am trying to install a cast iron claw foot tub for my wife in the bus and now I have came up with the idea Divorce maybe the best option ???
Have a good T Day people I am taking a break
Lin
Is the problem you are concerned with about how to secure it?
edvanland
Probably how not to get killed by Sona if he doesn't get it done
Ed Van
MCI 7
Cornville, AZ
gumpy
No experience with it, but my thoughts are, "Bwahahahahaha!"
Oh, sorry. I bet that's not what you were asking.
sledhead
my wife likes her baths . so I installed a bath tub in the M C I and riped out a beautiful kohler shower in the featherlite and installed a bath tub just not a claw foot . biggest problem is the shower curtain system for the claw foot tub look like crap . I had to use a L shape curtain system instead of the glass walls that were in the old shower  , but it sure made the bath room look a lot bigger   .
happy wife happy life
dave
dave , karen
It does make a bathroom look bigger I give her that,and securing is not a problem,to me it's the friggn plumbing and fixtures to go with it.It's a tub why do need 3 different type shower heads for a tub ? .The shower curtain and the rail looks good on the one she purchased and it should for the price,stepping up 2 ft to take a shower to me is dumb but I am losing the battle and the war  ??? I can only stall so long
Quote from: luvrbus on November 24, 2016, 10:45:54 AM... it's the friggn plumbing and fixtures to go with it.It's a tub why do need 3 different type shower heads for a tub ?
     I think I once had a plumbing project that wasn't like that but I don't remember for sure; if I did, it was a long time ago.
Quote from: luvrbus on November 24, 2016, 10:45:54 AM... I am losing the battle and the war  ??? I can only stall so long
     Yeah, you know what you gotta do.  Good luck with it (as oneah my favorite bus experts likes to say!)
sledhead
fixtures  ! fixtures  !  my featherlite is from the vintage 2000 remember . I have GOLD PLATED grohe bath , kitchen taps and drains ,  and for now there are staying only because it would cost me a small fortune to replace them and all the other shinny brass parts with the same high quality units . remember the shower sprayer that had all the different spray patterns it can do , some as a massage  ???
dave
dave , karen
Dave5Cs
Have installed a lot of them just not in a Bus. The phone handle shower head works the best. When done you hange it flat at the front of the tub. Slipper tubs are the most comfortable. If in a bus I would suggest a flexible drain joint maybe just under the floor so you don;t see it and flexible supply lines or joints also. Remeber you sit on the edge and slide the feet and legs in then stand up. Don't lift leg and climb in. Use the least amount of curtain down-rods as you can and placement of them is critical because of where you want the curtain to open and close. Get the soap dish that hanges over the edge and put it where you can reach it.  If you got the up pipe for the shower it also has to support the ceiling ring and curtain so side supports work well. HTH ;D
Dave
Utahclaimjumper
  Clifford,,,You will have to hold Sonia by the scruff of the neck until you are hooked up to a dump station if your tankage is too small.>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
Jeff Willard
Find a claw foot that still actually has claws. Then convince it hold on tight in the turns.
Jeff
4501-847 Scenicruiser
Sierra Vista, Az
Quote from: Dave5Cs on November 24, 2016, 03:33:27 PM
Dave
Dave
[/quote
Looks like I may have some help I heard you where going to be in my area the 1st of Jan lol see where experience gets you Dave,me,you and Lvmci so far  ;D  Van has been real quite
DoubleEagle
Depending on the size and weight of the available cast iron tubs, you might have a little bit of trouble wrestling it in the front door or window, or any hallway or door it has to go through. That might get you of the hook, plus we don't want to see pictures of you when you lose your grip and get crushed. That's no way to go, being crushed by a claw-foot.  ;D Maybe there are fiberglass reproductions.
Walter
Dayton, Ohio
Dave5Cs
Yep We could leave on the 28th of December and get be there on the 30th. That would give us until the (3rd through the 16th at the RV resort we got free tickets too) but could drive back in the jeep its only 20 minutes from you if we need more days. We leave Bull head city on the 17th for Quartszite. So there is plenty of room in there. Hardest part is getting it in the Bus and get flooring down first as well as any wall covering that might be behind it when done. ;D
Dave
