series 60 EGR for ddec V
Started by niles500, September 01, 2016, 12:05:47 PM
niles500
Need to locate an EGR valve for a 14L series 60 DDEC V, DD says they discontinued the original and have to do an upgrade, there has to be some old stock out there? Engine info below, currently in Augusta, Maine, thanks for the help
Engine family: 4DDXH14.0ELY
date mfr: Dec 2003
Spec. 51-0836
Model: 6067HV2E
VIN: 5-8387
(\__/)
(")_(")
- Niles
B_K
Niles from what I learned with the '05 Setras we had those EGR valves were a PIA and pretty problematic all across the board.
You should see if you can get a hold of Ken Arnold (aka Hardheaded Ken) from down around Murfreesboro, TN
I'm pretty sure he can help you out with a final fix to the problem!
I will leave it at that and let the two of you work it out privately.
Niles,is that oil operated EGR ? I have a old one
Detroitenginespecialist
We have these in stock.  All I need is the engine serial number and I can get you a price. Give me a call to discuss.
Brian Stanton
American Fleet Inc.
417.865.4420
417.234.7334  (cell)
bstanton.americanfleetinc@gmail.com
He is better off to upgrade to the newer EGR IMO
niles500
Sorry took so long to reply, and thanks for the responses. Found 1 discounted from Valley Power, the upgrade was over $7k, the replacement just $600, probably putting off the inevitable ☺
(\__/)
(")_(")
- Niles
B_K
Niles call me! I lost your #
mine is still the same two 7 zero - 7 zero 5 - 11 thirty nine
