Tag Weight MCI 9
Started by randsgmc5302, May 19, 2016, 08:20:37 AM
randsgmc5302
Hi i have 85 MCI 9 have 18,820 lbs. on the drive axle 4,080 lbs. on the tag should i add air to the tag to balance out some thanks Randy
That sounds just fine.
Your build plate will show the tag only rated for 6000 lbs.
thomasinnv
Tag axle regulator should be set at 35#
1998 MCI 102-DL3
Series 60 12.7/Alison B500
What's a typical drive axle and steer axle airbag pressure? 80 psi?
thomasinnv
Depends on the weight and the bags. With the old style double convoluted bags my 8 ran 55 rear 65 front. After installing the new rolling lobe bags all the way around it bumped it up to 65 rear 70 front to maintain same ride height. My guess would be possibly even more pressure for my DL3 since it's quite a bit heavier, but maybe not since the bags are a bit larger.
1998 MCI 102-DL3
I have the new rolling lobe bags all the way around in my 102C3. I'm wanting to bypass the leaky leveling valves and go completely manual with my pressures and wanted to know approximately what they should be set at as a baseline
thomasinnv
Scott the book should give you the ride height, just air it up until you reach the number in the book. I did the manual air level controls on the last one. For this one I am going to install the HWH air levelling  system. It maintains all the original system and ride height control valves for travel, just locks them out for levelling. It's actually a pretty neat system. Has it's own little compressor for maintaining level while parked, fully automatic.
1998 MCI 102-DL3
Nice. I'll check it out
