Air Compressor Air Filter
Started by john9861, March 11, 2016, 04:47:09 AM
john9861
I replaced my big square box air filter with a round Donaldson ECO Filter but in so doing I now have no place to plumb my air compressor supply line to. Is there a suitable filter that can be installed for this? How much CFM does the air compressor need? Thanks
John Mellis
Bowman, SC
1982 Eagle Model 10 6V92TA Auto
It's not the years in your life that count. It's the life in your years...
 John you can buy the filter and housing from NAPA that bolts to the compressor just use the 750 cfm number and you are good ,if don't find one I have a 1/2 dozen laying around here
When we turbo'd the engine, we disconnected the compressor from the intake and added the air filter directly to the air compressor. It is the smallest air filter I've ever seen. Most any big truck parts house will have the replacement for it. Or just cut and plumb in a new fitting on the new filter. Good Luck, TomC
Lee Bradley
My compressor air intake is plumbed into the pipe between the filter and turbo.  Just one less filter to buy and remember to change.
john9861
Unfortunately I cannot plumb to the new filter & there is not enough room in the metal pipe leading to the turbo & there is 2 rubber boots that I can't plumb to so I'll have to try the bolt on filter that Clifford is referring to. Thanks everyone.
John Mellis
Bowman, SC
Here is the Bendix number 278500N they have a couple on Ebay for 45 bucks
