Air horn valve?
Started by lostagain, February 04, 2016, 04:18:01 AM
lostagain
I would like an easier way to sound the air horn. Mine is the stock foot valve on the shelf to the left. It is back a bit, so it is hard and awkward to reach. Often I wish I could give someone a little hoot, but I don't because it is too much trouble. Is there a valve that I could mount up high with a rope that I could pull, like in a truck? Or I see hand valves in some catalogs that could be mounted within easy reach of the left hand.
What have you guys done?
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
Just hook it to the horn button on the steering wheel all it takes is the Hadley solenoid valve they cost about 40 bucks that is where I control my horn from I didn't like the foot valve but I didn't want the Lanyard valve with a cable or chain to pull either
ditto.
All the new coaches are solenoid activated. MCI favours a button on end of turn signal stalk, Prevost has been doing steering wheel buttons, either dedicated or selectable between air/electric horns by a dash switch.
That stock heel operated valve can be moved, if you desire it in a different place?
i have a select swicth on the dash for a standard 3 note electric horn or my air horn. both which work off the steering horn. easy peasy.
actually thinking of adding a third one.
Gary Hatt - Publisher BCM
I always wanted a horn that mimicked the sound of loud squealing tires that sounded like you were breaking really hard.  I figure that will get the attention of people in front of you that may have just pulled out in front better than any horn.  ;D
1999 Prevost H3-45
Lol. I always wondered why on earth the horn button was in a place that you had to basically act like you had to use the restroom to reach it. Weird. Awkward. Yeah, I definitely would have time to go through all that during a panick stop.
I have two twin air horns on my roof. I bought two truck type pull valves. Mounted them side by side with a pull chain connecting the two. Now I can just pull the higher one, or just the lower one, or pull both sets to get a nice 4 tone horn. When it gets really bad, I have my push button solenoid operated train horn (which I have used many times). Good Luck, TomC
Sealark
Where can you get a train horn, that would be perfect for those idiots that cut in front of you and slow down. ;D
Dan
1978 MCI 5C
6V92TA, MT644 Automatic, Ross power steering
Honey Grove, PA
Beesme
I bought my train horn on eBay 190 decibels .Very loud my wife gets annoyed when I just sound them off for her to get moving lol
Bruce E.        62 pd4106 vs730.
Gonic N.H.
