Making a 35 foot bus out of a 40 foot MCI 9 or 102
Started by richardmc9, November 01, 2015, 03:05:15 PM
richardmc9
Hello, a friend of mine wants to know if at all possible  to take five feet out of a forty foot MCI 9 making a 35ft bus ? I told him I would post the question  an I was sure that someone on the forum would know.  Thanks Richard
lvmci
Hi Richard, there is a MCI thats 35' and 102" wide, lvmci...
MCI 102C3 8V92, Allison HT740
Anything is possible...but why? It would be pretty major work. Better off buying a 35' coach.
bobwoo
I have had 1 5C 35 footer and 2 9- 40 footers. The extra 5 feet really makes a difference in layout and I didn't find any difference in driving the 40's. (my opinion), if I wasn't cheap I would of got a 45 footer  ;D
1993 MCI C3 L-10 Cummins
Tikvah
A sawzall, some duct tape, a couple hose clamps and - walah!
I would think if you took the whole coach down to the skeleton, it would be doable.  Then, from the bare skeleton, you could build everything exactly as you want.  Might be a great time to remove the tag axle - the tag would be overkill on a 35'
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
MC-5C is basically an MC-9 with no tag axle and one fewer bay.  You could shorten an MC-9, but it would be a lot of work.  MCI buses are monocoque, which in this case is a fully stressed skin over a steel welded tube frame.  The frame is not fully self-supporting, it gets much of it's strength from the aluminium skin riveted on.  You'd have to have the engineering and fabrication skills to join the two halves together properly.
Buy the exact bus that will serve you the best. I had to do many changes to my transit-ultimately should have bought a 102C3
Tikvah
If I were to build again, I would also do the 102c3 with the modern style engine.
Or, if I wanted to get to work with the welder, I'd build a truck... but that's another forum  :)
1989 MCI-102 A3
Dave5Cs
Brian mci 5C is a mci 8 without a tag and 35 foot
Sent from my SPH-L710 using Tapatalk
lostagain
Yea, I will join Dave in the nit picking, but a 5C is closer to an 8 than a 9. Not by much though. By the late '70s, MCI had evolved the 5C and the 8 to near perfection for the times. Then came the 9, a little better yet. I drove them all. The 5C was, is, nice and tight. The 8 had too soft a suspension and leaned in the corners. And for its 40' length, a large turning radius. The 9 was more solid on the road, had more power with the 8V92TA, and an improved turning radius. The next thing was 102" wide, and a new series. 40 year old memories...
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
Tom Y
Yes, Remove 5 feet. I wanted to remove 5 feet from my 5C. But decided against it because MCI did a nice job on the fuel tank. I removed 37 1/4 inches from the front area, added to the rear for the 6 cly Cummins. I did not cut the roof, left intact and slide to the rear. Slide roof back 1" at windshield also so not so flat at front. Then cut roof at rear cap. Left supports under bay area and slide together and some cut and weld.
Tom Yaegle
Tom Y
I wanted a 30 foot bus but did not make it. Here is a pic going together.
Tom Yaegle
Quote from: Tom Y on November 02, 2015, 06:07:43 AM
    Did you do a roof raise while you had it all apart?  That's a big job but it looks like you worked it out very well.  If I had my drothers, I'd have another 5' (although I already have almost 60 feet floor length).
