8V71 stuck injector?
Started by Sharkbait, October 22, 2015, 10:19:05 AM
Sharkbait
Hi guys, I finally made it back to my bus and started working on it. The motor hasn't been started in about 6 years (I know, I am now paying for my sloth).  Someone on this board in another post suggested pulling the valve covers and pulling the pin on the throttle mechanism and see if the fuel rack moves freely. Sounds like a good idea so that's what I did. The one closest to me moved fine. The one that's harder to get to is stuck. Any ideas to free it up before I start taking things apart.
Also, any tricks to getting the forward valve cover out? There doesn't seem to be enough room to squeeze it out with the right side being congested with oil lines for the generator and wiring and the left side not being tall enough. I thought maybe if I remove the breather on top of the valve cover I might be able to squeeze it out from the left. How do you guys do it?
I would like to try and rotate the motor by hand before starting. Da book says to use a bar back by the flywheel. Is there an inspection port or some other way I could access the flywheel side of the motor to move it by hand? As always thanks for your help and advice. Phil
Phil, PD4106-1726
 Can you still get to the access cover on inside rear? Or did it get covered up. Do not try to start it with stuck injectors!!!
Bill Gerrie
Bar the engine over with a 1 1/2" socket on the front cam pulley. You should be able to get the cover out if you remove the breather.
I had several stuck injectors, on the advice of Don Fairchild I pumped solvent through them for a while (a half hour) and they freed right up.  Barring the engine over so they get exercised is the first thing I would try.
If he has the new style spring load control tube with 1 adjustment screw per injector it won't hurt to start the engine,if he has the 2 adjustment screws for each injector it is a bad idea to start it
Sharkbait
They're unstuck. I removed the breather so I could pull the valve cover. I couldn't figure out which injector's were stuck so I removed the fuel lines from all of them and put PB Blaster in all the injector's. Took about 2.5 hrs but they all freed up. I now have to blow out all the excess solvent and re-connect the fuel lines. Then before starting it I think I will re-insall the breather but leave the valve cover off for now so if there's any leaks in the injector's lines I can tighten them up. Thank for the help, Phil
Phil, PD4106-1726
lostagain
While the valve covers are off, and before you start it, make sure that all the injectors go to the no fuel position when you move the stop lever on top of the governor. It is important to be able to stop the engine...
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
Sharkbait
Thanks, I'll check that before I start the engine.
Phil, PD4106-1726
Sharkbait
Got past the injector's problem. I watched a U Tube video on how to run the rack after I pulled the injector's out. Must have done okey since the motor started and ran pretty good. I've got another problem though. As the air pressure builds up it starts actuating the shut-off soloniod, the one on top of the governor. My question is, what is supposed to actuate that solonoid? Could something be stuck causing that solonoid to actuate? I see my problem being I just don't know enough to know what I'm looking at. Any ideas? Thanks, Phil
Phil, PD4106-1726
that plunger is controlled by a Skinner valve up on the bulk head...
take a jumper wire and energize the valve and then air will not "get to" the  plunger...
were all of your wiring intact shutting off the key switch would open that skinner to let air do it's job.
clear as mud ? :)
ps is this a coach that has a lot of hacked wiring...
Check the position of the front and rear start
Might be a bad ground connection at the skinner valve.  It should be "normally open", so no voltage and ground to it, it's open and passes air to the air cylinder.  When the front and rear switches are on it gets voltage and closes, blocking air from the air cylinder.  I had a bad ground wire once.
Quote from: Sharkbait on December 01, 2015, 01:14:41 PMGot past the injector's problem. I watched a U Tube video on how to run the rack after I pulled the injector's out. Must have done okey since the motor started and ran pretty good. I've got another problem though. As the air pressure builds up it starts actuating the shut-off soloniod, the one on top of the governor. My question is, what is supposed to actuate that solonoid? Could something be stuck causing that solonoid to actuate? I see my problem being I just don't know enough to know what I'm looking at. Any ideas? Thanks, Phil
     Phil, you have some good advice above, but think of it this way.  The air valve (Skinner) is there so that when it's activated, air shuts down the engine.  It won't work -- either for good or bad -- when you first start the engine and air pressure hasn't built up in the system.  So, if it doesn't apply when you first start up (normal and good, but it doesn't tell you anything) but air comes on and it actuates the shut-down, then it means the air valve is probably working as it should but there's some other part of the control system that's telling the air valve to do something you don't want it to do.
     It *could* be a problem in the air valve but it's much more likely that it's in the other parts of the system that the comments above tell you about.
Actually the skinner valve shuts down the engine if there is air and it's deactivated.  It has to be switched on for it to not send air to the air cylinder and let the engine run.  If the skinner valve fails it would normally fail open and so kill the engine as soon as air pressure comes up past 60 psi.
A lot of buses are wired if the front key is not on they shut down when starting from the rear @ about 60 psi,I never saw a Eagle that wouldn't do it fwiw mine does
