Best Washer & Dryer ?
Started by Darkspeed, October 13, 2015, 06:44:28 AM
scanzel
We went with the Spendide vented and I installed it in one of the bays, just open the bay door and it is right there. Vents through the bay floor located right next to my fresh water tank and hot water heater, drains to the black/gray tank. No noise to listen to when running. Didn't want to take us interior space since we have a side isle with a full size bathroom.
Steve Canzellarini
Myrtle Beach, SC
1989 Prevost XL
rip
My model was replaced with 500 series model 2840.Looks like the same as mine,220 volt.
jackhanow
If you pull an enclosed Trailer   Or gonna get one that is long enough to put them in the front. Less chance of the washer spin cycle shaking and breaking the bus and less
Moisture in the bus as well
don't panic, just fix it before.... 1966 mc5, 1986 102a2
bigred
We have the combo in ours which in my opinion is nothing but a waste of room.Not only is it slow ,but the small capacity is ridiculous !If I remember correctly ,they are rated for five pounds.If you spend any time in a camp ground,about all of them have some form of a laundromat.That is what we usually use.I like the way that laundry pair fit in your bay.It is like it was made for it.
Tikvah
For those who don't like the combo - question.   Are you using vented or non-vented.
I hear lots of complaints from the non-vented folks.... but most folks seem to like the vented Splendide combo
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
I have a Bendix non vented and Splendide vented setting in the shop I can't tell the difference the little 2 in vent on the Splendide couldn't vent much with piping if you put a 90 in place to go through the floor to the ground
digesterman
We have a vented splendide that I put a inline fan on the vent tube which goes down to vent under coach, improved the dry time but they are for small loads only, wife likes, I don't, but for a couple they will do
Lee
Le Mirage XL 45E
Detroit Series 60
470HP
Todd -
I tend to agree with Chessie.  For the cost and aggravation of trying to stuff a W/D into a 35' coach, you can do an awful lot of clothes at the laundromat, plus normally in/out in 60-90 minutes for all of it.
I dont' have a w/d in my 5C, no plans to remodel to accommodate, either.
Trust me men don't care where they wash clothes at, but most women hate a laundromat mine will tell you in a hurry she travels in RV because of fifthly motels and hotels and she is not going to wash clothes in machines no telling what it has been used to wash.
Lol I had to deal with it for over 40 years and the last time I checked it has not changed with her so she gets a washer and dryer." A happy wife a good life"
gg04
Quote from: luvrbus on October 16, 2015, 11:51:16 AM
.        I agree with what he said.. 40 years tomorrow..lol
If you personally have not done it  , or saw it done.. do not say it cannot be done...1960 4104 6L71ta ddec Falfurrias Tx
Darkspeed
For me full timing without a washer and dryer would be a pain. Fire and Clean clothes  = civilization
It's all math and metal...
Tnghost
Wash em in a creek and hang em up is what we do
75 mc8 bubba and Marie somewhere camping in tennessee
Scott-do any of these souls with combos have the air dry unit from Splendide? If they all have ventless, I agree. Good Luck, TomC
We checked into a new 2100 Splendide vented the book said 1 to 2 hrs for drying time it has a high and low heat selector for what I don't know I couldn't find a heating element no where in the parts book.
Only difference I could find was the non vented model used 3 gals of water per hour for drying and the vented model used none only room temperature  air no heated air from the dryer its self drying time was the same on both.
A lot of the new house type use that same system drying with the room air,ours does and it sucks
I know my ventless Splendide gets quite warm during the drying cycle. And since both the ventless and vented model require 1300 watts (the motor certainly doesn't draw that kind of amps) and the fact that the exploded parts drawing called out the heater and heater control, plus a switch for less heat during drying, I'm quite confident there is a heater for drying in both the ventless and vented models. Good Luck, TomC
