How do you remove paint from a bus?
Started by Charles in SC, September 10, 2015, 06:04:31 PM
Charles in SC
My 5303 is steel around the windows and aluminum every where else. Lots of rivets. What is best? Stripper? Sand blast? Orbital sander?
Darkspeed
It's all math and metal...
Stripper and power washer I have good luck with the GAR 343 Klean Strip pricey but works
gg04
This last time I borrowed a oil field blaster and soda blasted. Then cleaned up with a da. Used nearly 1000lbs. Only did rooftop.rdw
If you personally have not done it  , or saw it done.. do not say it cannot be done...1960 4104 6L71ta ddec Falfurrias Tx
