Symptoms for Stuck/overfueling injector
Started by Seangie, August 28, 2015, 12:28:06 PM
Seangie
What are the symptoms of a stuck or overfueling injector?  Anything I can look for while driving or physically look at that would indicate a problem?
Thanks.
'Cause you know we,
Driving through the night
To that old promised land'
  A stuck injector you will lack power till the engine reaches the point where it is stuck at above or below it will miss,shoot all 6 exhaust ports on the manifolds with your IR gun that will tell a you lot they should all be the same +or- 5 degrees
Boomer
You might have a blown tip Sean.  Loss of power, rough running and black smoke under pretty much any acceleration.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
North Idaho USA
Quote from: Boomer on August 28, 2015, 03:29:08 PM
which would put raw fuel in the exhaust.... causing high heat in the turbo.
but your turbo is not free spinning ?
Seangie
Don,
Ill take a video tomorrow.  It spins but not freely like a bike wheel.  Maybe a revolution and a half.
Talking to a mechanic today and he said if the Turbo was freshly rebuilt it was a very slim chance there would be an issue with it sans completely locking up with no oil.  He mentioned excess fuel from an injector could cause similar issues as to what I am experiencing.
Mark-
If I pull the valve covers will there be any tell tale signs?
Also -  would the broken tip damage the cylinder/valve?
Thanks guys.
'Cause you know we,
Seangie
Quote from: luvrbus on August 28, 2015, 12:37:21 PM
Sorry Cliff -  I missed this.  I will run it tomorrow and shoot it.  Thanks for the tip (ha!)
I did notice a slight loss of power in the mountains and additional heat. So climbing grades I should have been able to pull at 44-46 mph in 3rd I was having to drop to second and pull at top RPMs at 38mph to keep it cool and had a slight.loss of power.
'Cause you know we,
