Clutch problem
Clutch problem
Started by Raymond smith, August 25, 2015, 01:32:43 PM
Raymond smith
102C3. 6v92 5 speed. All of a sudden i got lots of freeplay and can not get it into gear now. Any thoughts would be greatly appreciated. Thanks. Raymond
1957 4104-3632 & 1989 mci 102c3
If it doesn`t fit properly the first time, Get a bigger hammer
Have someone push the pedal and check to be sure the linkage is working at the rear,if you see sparks coming from the inspection hole it's clutch time !!!!
Or throw-out bearing.   Which is about the same thing, PITA-wise.  One usually takes out the other.
