MC9 kick down cable "sticky"
Started by plyonsMC9, July 30, 2015, 12:44:57 PM
plyonsMC9
Good afternoon,
On our 83 mc9, the transmission kick down cable (if that is what it's really called) appears to be sticky.  With the cable attached, the pedal doesn't snap back when the accelerator pedal is released.  But we can downshift when necessary.  Without the cable attached, the accelerator snaps back into position. But of course downshifting doesn't happen.  We've tried lubing the cable a few times.
Has anyone else dealt wth this?
Thanks!  Kind regards, Phil
 Could be the modulator on the transmission has gummed up most have 5 small bolts to remove the cover to clean the inside could also be you have a modulator going bad, that cable controls the modulator
plyonsMC9
Further clarifications! It's a Morse cable, and when we lube the cable it snaps back pretty good for a few minutes, but then it slowly gets gummed again.
Thanks again!  Kind regards, Phil
Trace the cable from the throttle it will go to the modulator on the drivers side of the transmission,only 1 bolt and clip holds the modulator to the transmission easy to remove and clean just don't lose the modulator pin and plug the hole or it will leak transmission fluid till it gets below the modulator.
LOL if you could talk Gary into making this board more photo friendly I could post you a photo of the modulator and cable
plyonsMC9
Much appreciated   ;D  - will give that one a look.  Maybe if I can snap a picture I will put it here to make sure I have the right thing?
Hopefully when we upgrade the forum software, the post picture process gets simpler.  No guarantees tho'!!  Sorry about that frustration.
Kind Regards, Phil
Gary Hatt - Publisher BCM
Luvrbus,
Funny you should mention making the Forum more user Friendly.  This is the next task on our Webmasters ToDo list.  He just upgraded the Subscription Manager so now you can choose "Forget Password" to reset your own password and also check to see when your magazine subscription is set to expire and renew your subscription right on the spot.
His next major project is the upgrading the Forum Manager, so start taking those photos and hopefully within a month or so, you may be able to upload photos.
Gary
1999 Prevost H3-45
You are a good man Gary even if you do wear suspenders next time I see you the beers on me
Gary, I still have a now expired free subscription to the online magazine but never got a call back. Spoke to some nice girl months ago but never heard back
