Hub cap manufacturer and part number?
Started by Brian Diehl, June 10, 2015, 07:02:16 PM
Brian Diehl
Anybody have a part number for the MCI hub cap that I could take to NAPA and they look up?  I'm hoping someone has a manufacturer and part number that works.  The plastic on my hub cap is now leaking.  The MCI part # is 15R-2-13 and Mohawk wants $31 plus shipping.  Would be nice if I could pick it up at my local NAPA if possible.
Thanks.
I replaced all mine with the SKF-1643 I like those because they have a fill and drain plug you don't need to remove the center plug I paid 26 bucks each through a mom and pop auto parts here in the valley  fwiw
Ed Hackenbruch
I think that i got mine from a Roush truck repair shop, for about the same price as Clifford got his.
Brian Diehl
Thank you guys!  I'll see what Napa can do for me with that part number.  they sure as heck don't know what to do with an MCI part #.
bs4104
CR 1798 PN:  NOS1798 MFR:NAPA Oil Seals  has a 6 hole on 6" center
SKF- 1643  has 6 holes on 5.5" center
check out witch fits yours.
Had...
102A3 N14 Auto Shift
also two 4104
wildbob24
Brian,
All they've got to do at the NAPA store is leave out the hyphens and the MCI number will cross over to the NOS 1798 cap mentioned above.
Bob
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
PD4106-2546, 8V71, 4sp
Greenville, GA
Brian Diehl
The front hub on my bus had 6" on center bolt holes.  The CR SKF part is 1798.  Worked great.
Thanks all for the help!
IMABUSBOY
Quote from: bs4104 on June 11, 2015, 05:54:50 PM
Happiness is not found at any destination, it can only be found on the journey.
Keep your eye on the sparrow.
IMABUSBOY
Thanks bs4104 Napa had the right hub seal
