8V71 thermostat housing gasket
Started by peenhead, June 06, 2015, 01:01:10 PM
peenhead
Looking for the part numbers for the thermostat housing gasket,8V71, NAPA would probably be good or a place to order online.
5117786 (2) did you get the housing apart without twisting a bolt off  ??? buy your online parts from PC Industries in WY,if you don't find the gaskets Dennis I can mail you a couple
Geoff
Make your own-- buy some gasket material
from AZone, etc., and use a ball peen/flat edge  hammer to trace out the gasket.  Basic mechanics.
--No name on this one.
Geoff
'82 RTS AZ
baker4106
I believe you will find two different kinds of thermostats.    My 4106 has bypass thermostats and the regular ones don't work.   Without thermostats the coolant is not sent thru the radiator.
Nope Dennis has a Eagle both T stats are the same,I sent him some gaskets fwiw
