Anyone have a photo of a black MCI102DL3?
Started by Scott & Heather, March 26, 2015, 07:01:08 AM
I can't find one anywhere on the web. Been trying to see what an all black 102DL3 would look like.
ol713
  Hi;
    I think they are rare.
                  #1 They are hot during the summer even with air conditioning.
                  #2 They  need frequent washing.  They look dirty/dusty all the time.
                                                     Merle.
Ok then. They are as rare as a unicorn.
or bigfoot
daddyoften
68' PD 4107
Central WY
PP
Hey Scott,
Have you tried photoshopping your bus? I use photopos pro it's a free photo editing software that works very similar to photoshop. I took a side view of my bus and changed the colors from blues and greens to reds, rusts, all different hues to see what it would look like with a new paint job. Still haven't gotten the paint job, but we sure have eliminated a range of colors and patterns LOL. HTH
Will
Check for black E models MCI not much difference in 2 I seen several of those for sale sharp looking in the black
lvmci
I've seen a lot of buses with rust color! lvmci...
MCI 102C3 8V92, Allison HT740
scanzel
Black looks great but a lot of upkeep. Has a black 61 Thunderbird at one time looked great washed and polished but one day out and dust made it look brown. White or some variation of white is the best to reflect the suns rays and heat. Get an infrared heat gun and check out different colors in the direct sun and you will see which one is hot. I did this on my bus which has black and white and what a difference in temps between the white and black. White I could put my had on it black was so hot you could not keep the hand on very long. I once measured my tinted glass side windows on the inside in August in direct sun and it showed 135 degrees.
Steve Canzellarini
Myrtle Beach, SC
1989 Prevost XL
lvmci
when you grow up in the desert, black vehicle's are not the color of choice. lvmci...
All true. I'm never going white again. It's great, but I definitely want a prettier color on the next coach. May do some sort of graphite color. Still coming up with ideas. Black is sharp. Cliff, I have photos of the EL3 in black and its sharp.
Hey Scott,
My bus before the paint job.. I drove it a year in flat black.
Better have oversized A/C systems.. Sucker got real hot!  Outside surface temp on a 90 degree day
was 195 degrees. A white van right next to my bus was 131 degrees. Big difference! This is why I
incorporated mostly White into the paint job.
Ed Hackenbruch
We have 4-5 shades of blue on our bus. Yesterday it was 98 degrees and i took temp readings on different parts of the bus. Highest i had was 154. On a 104 degree day i have had 184 on that same spot. We are not well insulated,( done in 83, no high tech stuff then). Yesterday on the inside in the front half with no ac on we had a temp of 113.2......white is looking more attractive.  :)
   I wonder if the temp reading would differ from steel, aluminum, or fiberglass.
lvmci
hi Chessie, I think fiberglass doesn't transfer heat as much, there is a paint with ceramic particles in it that almost eliminates heat absorption, forgot the name. lvmci...
BeastMaster
Aren't the President's buses painted black? My Beast is all white.
Sent from my SM-N910T using Tapatalk
1989 - MCI 102C3 8V92TA T740
Converted by Dick Lamb, Custom Land Yachts - 2005
Famous Margaritaville Bus
Star of the Duncan Family Counting FireFlies
