Unique GMC "4905"
Unique GMC "4905"
Started by pabusnut, January 20, 2015, 08:41:51 PM
pabusnut
Found this on the E-place, when looking for something else.  Item number: 251799558005
http://www.ebay.com/itm/1979-GMC-Coach-Bus-Conversion-4905-40ft-Class-A-Detroit-Diesel-RV-Motorhome-/251799558005?forcerrptr=true&hash=item3aa06c5775&item=251799558005&pt=RVs_Campers
It looks like they raised the original lower cap up to the top roof, and added MCI? windshields.  It kind of looks like one of the prototypes they had for the follow on to the 4905 or maybe it is it?
Steve Toomey
PAbusnut
Steve -
Those are 96A3 MCI windshields on this buffalo.  Somebody went to a lot of work to customize the front end for them to fit.
It is not the prototype for the replacement model.  GMC called the Buffalo's replacement the Triton II, here's a pic:
Purplewillie
That's the 4905 Ros wanted. The one that wouldn't climb a hill he said.
Seller has a low feedback. And it's a H8H649 same as a 4905, just newer.
Mark
Mark & Char
1976 P8M4905a 8v71 v730
British Columbia Canada
oldmansax
Like that exhaust system...............    :D :D
TOM
1995 Wanderlodge WB40 current
1985 Wanderlodge PT36
1990 Holiday Rambler
1982 Wanderlodge PT40
1972 MCI MC7
digesterman
I was wondering 3 speed with 300 hp, not a fast coach by any means.
Lee
Le Mirage XL 45E
Detroit Series 60
470HP
iirc, i talked with the owner...the front end rotted away, hence the replacements...it was a NE bus, ohio maybe, and has been driven very little.
Quote from: eagle19952 on January 21, 2015, 06:30:37 AM
Tracing the VIN posted in the eBay ad, H8H649-027 was delivered new in June of 1979 as fleet number 69 to Ellmas Bus Co (dba Academy Bus Tours), HQ'd in Hoboken, NJ.  So yes, a Rust Belt bus.
300 hp 8V71 with a V-730 is no race horse, and certainly no match to any Series 60-powered coach, but that's a common powertrain swap in a GM.  It may not win any drag races, and you will have to downshift pulling Rocky Top, but it will roll right on down the highway happily at 65 mph.
Purplewillie
8v71 v730 in our 4905, not a fast coach by any means, but she still climbs out of BC just fine
I don't have that custom exhaust on ours...
Mark
Ps Go Hawks
Mark & Char
Beesme
I think it's pretty good deal ! Lot of coach for the money . I'm sure not getting up a hill is easy fix or just not used to how fast a big ole bus goes up a hill....
Bruce E.        62 pd4106 vs730.
Gonic N.H.
the ebay seller appears to not be the owner.... apparently he is using/allowing a broker to offer his bus, unless the current offer-er has bought it and is reselling it ???
clear as mud ?
pabusnut
RJ,  thanks for the corrected history of the prototype.
I guess none of us with the factory spec 8V71 in a 4905 are going to be winning any drag races or screaming up mountains.
On the subject of climbing mountains, Uncle Ned gave me a little scare when I talked to him about the route I was taking after leaving his place.  He said I would probably only be doing 25 MPH when I got to the top of Fancy Gap on I-77North.  :o What a kidder! ;)  I did top it at 45 MPH and could have gone faster, but I was "drafting" a semi, and I didn't think tying up both lanes in the dark, rainy, foggy night(a weather trifecta) would engratiate me to any of the other folks on the highway.  I might have been able to hit 50(in third) if the truck wasn't there.  Uncle Ned was probably chuckling the whole evening.
Wait, maybe it is Huggy that can only make it to the top going 20!!  ;D :D
Steve Toomey
PAbusnut
Don't feel bad, and be careful what you wish for...
An MCI EL3 Renaissance with a 400hp. S60 and a B500R 6 speed Allison with a load in it climbs Fancy Gap at 50mph, in 4th direct or 5th, the first O/D, same speed, that's it.
1/3 more HP doesn't mean 1/3 more speed!
Happy coaching!
uncle ned
Pabusnut
I said it was 25 to 30 if the temp. was above 70 degrees. if it was freezing rain 55 to 60 was easy.
HP in a detroit makes heat.
did you have a great trip and we missed you at Arcadia.
uncle ned
4104's forever
6v92 v730
Huggy Bear
DMoedave
10-4 on the over 70. At 85 degrees we took a sandwich break just before the top :/
we love our buses!!! NE Pa or LI NY, or somewhere in between!
