Tires - Page 4
Tires
Started by mung, January 18, 2015, 06:34:08 PM
mung
I wouldn't even attempt to do a split rim.
As far as the date codes, it is pretty easy.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11
Vern in Central Florida
PD-4104-772
What you guys calling a split wheel ? those things haven't been around since the 70's the lock ring wheels are still sold and serviced daily unlike the split wheel where you could only mount tube type bias tires on , you guys confuse me sometimes is that a get even or what ::)
mung
This type is what I think most are talking about.  Yes they are still in service today, but not something I would mess with.
http://www.ehow.com/list_7426633_dangers-split-rim-wheel_.html
PD-4104-772
Lin
My former bus had lock ring, Dayton wheels.  In theory, they are much easier to mount tires on than the one piece rims.  The problem is that the ring can be launched when inflating and really hurt someone.  I believe that law requires shops to air them up in a protective cage-- at least that is the case in California.  I did have tire guys just do the whole thing on the ground on a service call, but they would tell me not to try it myself.
lvmci
I had split rims on 14" wheels, on my Streamline 28' aluminum travel trailer, hard to find people to change a split rim wheel tire in LV. Clifford they where tubes too. lvmci...
MCI 102C3 8V92, Allison HT740
uncle ned
I have a set of 4 split rim alco  22inch wheels for sell cheap.  come and get them.
uncle ned
4104's forever
6v92 v730
Huggy Bear
Now Ned is telling his age 22in Alcoa's with a steel lock ring and not a typo they were 22in not 22.5 I saw a set today on a old Mack
mung
I had to go by Northern tool for some straw hats today (the only local place that had them and we needed them for a charity event this weekend) so while I was there, I picked up a tire inflator setup that had 1/4" after the control valve/pressure gauge assembly.  An airline coupler setup and I have an inflator that I can put as much of my regular airline hose in as I want.  So hopefully that will give me safe distance from the tires to make sure I am not too close if there is a zipper.  I will also make sure to inspect the tires before I mount them.
Hopefully that is enough to make sure I am being safe.
PD-4104-772
uncle ned
Yep Cilfford us old people have seen a lot.
My 1953 model bus is just a kid compared to me
have a god day.
uncle ned
PS expecting freezing rain tonight here
4104's forever
6v92 v730
Huggy Bear
