Deadbolt lock
Deadbolt lock
Started by saddleup, December 22, 2014, 03:00:48 AM
saddleup
Been trying to find a deadbolt lock for my Eagle door....it only about a inch thick anybody know a source...
Yuma,Az
mung
I used the cheap one from Home Depot and took the outer trim ring off, it works fine.  Now that is on a 4104, so I don't know if your door is thinner or not.
Vern in Central Florida
PD-4104-772
Prevost  ;D Locksmiths sell what are called store front locks that are close I think that one is a Cookson
Dave5Cs
Any commercial door and lock shop will have a schelage that you can put any size connector in which they should also have. ;D
Dave5Cs
   Could you reverse it; put the key part in main coach body so the deadbolt enters the door instead of the other way around?
siberyd
I agree with Cheesie,  I have seen the reverse version on several coaches.  Its less cutting of the door and adds a cleaner look to the door.
Siberyd
1957 PD 4104-2240 Lawn Art
His is in the door already he can find the replacement he is not going to like a house type that stands out about 2 inches his now only stands out about 1/4 of a inch from the door. I am just going to enjoy watching him squirm at the price from Prevost  ;D
PP
The one in my old Prevost is a Corwin and I priced a replacement for around $200. just last month. I removed it and took it to the local locksmith and he made a replacement part in his miniature machine shop and it worked great. He then rekeyed it and threw in a couple of new keys and said twenty bucks. Needless to say I gave him a tip. Old guy in a small town and he wanted to show off his skills --- I let him.
Will
Boomer
I have a Trimark in my Eagle.   Good folks to work with, and the latch assy. is a combination with integral deadbolt all in one unit.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
North Idaho USA
Have you found a replacement Matt a friend of ours called last night and was concerned you didn't answer back about the dead bolt but I assured him you were ok you were just in mourning thinking about parting ways with the dead presidents   ;D I have one of those new some place I looked all day for it no find yet
saddleup
Clifford and others I just been waiting and seeing what people come up with ...no I am not goin to go buy some prevo high doller lock , been looking at the trimark lock that boomer suggested....my deadbolt I have works and I have got in the habit of locking it before I drive of,its just so low on  the door its a pain in  the @$# to lock and unlock...as in the wife cant work it...also thinkin a short piece of logchain and a padlock would keep; the door from comein open driven down the road...lol     THANKS FOR THE IDEAS....even Clifford....
Yuma,Az
The way your door is made it will take some modification to make the Trimark work I have a air cylinder lock here for you I was planning on installing at the top then you just flip a switch
I just never got around to installing it to stop the door movement at the top when underway  it's here if you want it I found it yesterday looking for the spare dead bolt I thought the dead bolt had broke
mung
This is what I am using on the 4104.  http://www.lowes.com/pd_279854-51800-DLX71_0__?productId=3142301&Ntt=gatehouse+deadbolt&pl=1&currentURL=%3FNtt%3Dgatehouse%2Bdeadbolt&facetInfo=
The trim ring comes off and you can mount it flush against the door so there is only a very small lip on it.  I can take a picture when I get home if anyone wants to see what it looks like.
PD-4104-772
Quote from: mung on December 23, 2014, 11:19:37 AM
    Hey, Vern.  That's similar to the deadbolt I used but I have a fairly large window in my door and it would be easy for someone to break out the glass and reach in to open the lock using the lever on the inside.  Mine has the "double sided" lock and you have to use the key on both sides.  There is an emergency key nearby inside the bus so anyone can quickly unlock and get out in an emergency, but nobody trying to break in from the outside knows that.
You remove the trim ring then all it takes is a pair of Channel Locks to twist the lock open,that is the purpose of the ring to prevent twisting the lock
