Need Muffler and left and right windshields for 1975 4108.
Started by Carter, August 14, 2014, 09:26:02 AM
Carter
Anyone with a source for a muffler new or good used for my 4108? Original part # is 677287 according to my parts book. It's tall, and sits vertical in front of the 8V-71. Also source for new windshields??  Thanks
That muffler is really stuffed up. Many other mufflers available-especially if you're thinking of uping the horsepower. Good Luck, TomC
   Please, at least. list what state you reside in in case someone nearby has these parts.
Carter
Carter
Thanks Tom C.  I know that muffler is really stuffed up there....a challenge to replace.
What would be starting place to look for other mufflers that might be available?  Truck dealerships or other bus companies???
   Windshields fit several models and brands of coaches. Check with larger glass companies. I'd have them change them, so if they crack one. it's on them. Check with Luke for new seals.
www.coachglass.com should have the windshields the muffler is another thing it's so heavy just cut the top out and clean it then weld it back together
   Find a metal fabrication shop and have them duplicate it.
zimmysurprise
Hey Carter- I replaced the windshields and gaskets on my 4108 last year. I chose Curved Glass in CT for the glass, and Jefferson Bus in OK for the gasket. Windshields were about 150 each and another 150 for shipping. Gasket was about 100. Any pics of your 4108?
