Door hinges 4106
Started by Beesme, August 05, 2014, 04:26:47 AM
Beesme
I just installed new rubber hinges on our 4106 . I was expecting it to be a real pain in the &@$@ haha . But with the aid of my garbage tote it was a breeze . Only one person and it took 30 min per door !
Bruce E.        62 pd4106 vs730.
Gonic N.H.
They're not bad once you get the hang of it. The most work is cleaning the hinge grooves of corrosion.
I used a kid's wagon to hold/move the large doors.
travlinman
Hey Loveshack
Who was your parts source?  I am just about out as mine are slowly failing.
TM
Steve & Kristen Full time nomads since '06 - PD4106-674  8V71/V730
This bus is for sale - https://gm4106.wordpress.com
jimsflx
jim&roenie seagraves sebring fl. 4106-3083
Be sure to get fresh rubber and use SS screws to hold the hinges. Old corroded screws are a real pain to remove.
I used hinges that came with my 4104 and they lasted a month. Fresh ones are still there with no sign of tearing after six years.
Keep the doors closed as much as possible. The full door weight is on the rubber when open, none when it is closed.
Beesme
I'm sorry travlinman I just got back from a trip with the bus . But I got the  rubber and other pieces from bus service inc 605 Sharon springs is 67758 but phone was from tn that number is 615 666 8500 they were fast and inexpensive see ya
Gonic N.H.
