Teach me how to drive this Manual
Started by Bryan, March 18, 2014, 03:11:45 PM
Bryan
Hey guys, Most of you know the 4107 4 speeds were known for grinding gears. Even when you read the history, drivers were even sometime embarrassed that passengers had to hear the grinding. When I drive, there is a good bit on grinding, sometimes even hard to get into gear, I feel like there could be a lot less grinding if I were given some pointers. I've driven a stick all my life in my car. Sometimes double clutching helps but sometimes it doesn't. I have really found my groove yet... any suggestions?  ;D
Bryan
1996 Prevost XL
1967 PD4107
Toccoa, GA
baker4106
4107's grind going into 1st so shift into 1st before starting and shift into 1st as you slow down just before it comes to a stop will stop most 1st gear grinding.   You must shift all other gears with double clutching.   Time your shifting with governor and most grinding will stop.
My 4107 is AT but my 4104 is manual.
I shift up without using the clutch, the secret is having patience - it just takes a little pause while in N.
Down I always double clutch very fast on a hill, level I don't use the clutch.
I agree about being in 1st before starting!
I also try to shift into 1st right before stopping if I'm continuing on. It is much easier to go to 1st when barely moving.
DMoedave
The pause of patience is the key! wind up and clutch out of gear clutch up and down and .... shift. RJ has a real cool lesson on shifting if not here for sure on Busnuts website under articles. Good luck. shift slower!
we love our buses!!! NE Pa or LI NY, or somewhere in between!
Tim Bookmiller
Find and read RJ article on shifting ---it is ALL in the timing -between double clutching -- and engine rpms. From 1st to 4th is all in double clutching and timing .....to down shift from 4th to 3rd or even 2nd  requires a raise in rpms and here again timing- practice make every thing better. And like said before JUST as you quit rolling for a stop EASE  er  in 1st  you will be good to go
Bryan -
http://busnut.com/forum/index.php?action=articles;sa=view;article=41
Give me a day with you and I'll have you shifting like a "real" bus driver - not like today's "stab n steer" jockeys who cannot even manually shift an automatic properly.
But try the above first!
Tim Bookmiller
He will want to read VERY carefully and thank you for the link He should be able to get er done now
Seangie
We spent the money and flew RJ out to give us driving lessons.  Granted we have an automatic (oops - not manual) tranny but it was still worth every penny and we learned a ton.  So many things we had no idea about.  It will certainly change the way you approach driving a bus.  He also drove our bus like a sports car.  I never knew my bus could drive like that.
1984 Eagle 10S
www.herdofturtles.org
'Cause you know we,
Driving through the night
To that old promised land'
rgrauto
Bryan if you need me to give you some pointers on shifting (I have done a bunch of it ) just give me a call and I'll drive over, check clutch adj.and we will take it for a drive and I'll show what you need to know .
wdtjawshwdt
I only double clutch when down shifting.  I drive truck for a living but I will try to describe this in the best way possible.
So you start the vehicle and if you haven't moved anywhere, you can probably slide it in and out of gear.
Basically there are two spots in these transmissions.   You have a High rev shift and low rev/idle shift.   And it is all about matching throttle response/RPMs/speed to the matching gear.
Think of the gears having two speeds.
Low 1st (idle speed), High 1st(pedal to the floor wound out speed), slide out of gear, Low2nd gear (close to idle/low rev speed and as you hit the gas)  High 2nd (pedal to the floor), slide out of gear, Low 3rd and you missed you can flutter the gas pedal just around the idle/low rev speed until you can slip it into gear, Wind it out, High 3rd gear, slide it out of gear, low forth gear, wind it out high 4th so on and so forth .   None of the shifting has been done with the clutch depressed.  You might be able to even shift through you
This is all done with syncing your engine speed to your transmission input shaft speed (or something like that).  If you want to practice on something cheaper you can actually drive a standard car by timing your shifts.
Play with that gas pedal a little more and hopefully that will get you shifting a lot smoother.   In a truck it is easier to hear how the gears are grinding.   In the bus you are going to have to feel it more.   And by that is a buzz saw that I am trying to force the that gear through or does it feel more like fitting a key in a key hole at night?   Lol Analogy central!
When I first started driving when I came up to a stop light I dreaded when it would turn green if I wasn't at a complete stop.   No need to panic!   Just take it easy and see if you guessed the right gear to slide into.   Lol otherwise take advantage of first in you are just hanging out in the middle of the road.
Good luck :-)
Josh
1981 MC9 6v92DD 5 speed fuller
RIP 1996 Amtran dt444e
Farmington MN
wdtjawshwdt -
Nice commentary for a newbie!  Glad to see others pitching in to help.
Your thoughts, tho, did bring up a question that will help you understand what Bryan's up against:  Does your truck have a wet clutch?  Whole different animal when it comes to putting it in gear at a dead stop.  Plus they shift quite differently between cold and hot.
The 4-spd transmission in Bryan's 4107 has HUGE gaps between each gear, something that drives truckers totally crazy until they figure it out, then it frustrates them to no end because there aren't more gears!
rgrauto -
Good suggestion about adjusting the clutch before a driving lesson, in addition to volunteering to give Bryan a hand.  Just be aware that proper clutch adjustment on a GMC starts in the exterior compartment underneath the driver and you work your way back from there.  Quite different than an MCI.
Seangie -
Thank you for your kind words, they're appreciated!  (Oh, and since when did you take out the automatic and install a manual gearbox?  Was that one of those conversion projects that didn't make it to the blog?  Hehehehehe. . . )
Bryan -
Let me know if you can't open the link in my previous post.  I'll send you the article in .pdf format.
Bryan
I knew this was the place to come to learn how to drive! haha! Thank you everyone for your input...
RJ, I can't read the article because for some reason I still haven't been approved for busnut.com. I registered a long time ago. I submitted under a new username tonight, so maybe this one will go thru. My username is "bshoc" if you know someone over there that can approve it.
Glenn, I've been meaning to catch up with you on the phone. I would love to take you up on your offer! I will definitely give you a call soon.
Again, thank everyone for being so helpful.
Bryan
1996 Prevost XL
1967 PD4107
Toccoa, GA
Bryan
Bryan
1996 Prevost XL
1967 PD4107
Toccoa, GA
wdtjawshwdt
I have an MC9 and it seems like I should just stand on the gas and shift.   And it is a different beast compared to truck.  But when I drove the MCI for the first time it felt like the first time driving truck.  Shift points were just a little different.   My timing was all off the first couple hours of driving it but it started coming together.
I have faith in you Bryan...hopefully your transmission does too.   :-p
Josh
Farmington MN
Runcutter
Bryan, I drove and instructed on 4903's (big 4107's) and 4905's (long 4108's) in service.  We always double clutched, going up and down.  Always blip the throttle on downshifts.  (Clutch in, out of gear, rev engine, clutch in, ease into lower gear.)  As stated earlier, you're trying to match the revs of shafts & gears.  Always ease into first before coming to a complete stop.  Some coaches would go into first at a stop, most would not.  Here's the point.  Every coach shifts differently, you have to learn (listen) to what your coach wants to do -- cold and hot, uphill and downhill.
That's what I taught, and what I did (mostly).  On coaches I was familiar with, I'd go up without the clutch occasionally - just for the heck of it.  I don't remember, but probably tried it going down, too.  I was decades younger then. Now, if I were paying for any damage, I wouldn't do it.  If I were managing an operation again and caught one of my drivers doing that, it'd be time off for bad behavior.
One fishbowl we had (4104 transmission) shifted so fast that the driver risked arm injury.  Even two sister buses, with consecutive serial numbers -- shifted differently. I recall that I couldn't blow a shift in 246, but 248 - both 4905's  was an average coach -- make most shifts, but blow one occasionally.  (Our coaches all had even numbers, owner's son had been killed in an odd-numbered coach, and he would never have an odd-numbered coach again).
The first year we had air-throttle buses, 4905's 252 & 254, I never could shift the darned things.  Engine revs would die down too quickly.  Other drivers could handle them, but I hated those buses.  I'd never take one out to instruct, since I couldn't shift the darned things to my satisfaction.
Arthur
