Stove hood
Stove hood
Started by Flight102C3, March 15, 2014, 10:36:31 AM
Flight102C3
   Hi everybody, got a question about what brand of vent hood you are using? I'm sure I would like to vent to out side. Won't be able to reach flapper on the out side. Wondering about the louvered vents? Thanks for now!!!
Lee Bradley
Where is your stove? I have mine on an island in the middle of the bus to make room for a microwave with a range vent. I added a duct from the microwave to a ceiling powered vent. I have to run the ceiling vent when I run the stove vent but one less hole in the roof.
Jriddle
I put a regular hood vent for a RV on mine. I use a stick to move the locks on it. You may be maybe different than me but I can't stand the flopping noise while driving down the road. I sure the louvered kind would be worse.
My Way John
John Riddle
Townsend MT
1984 MC9
Lin
Ours came with the hood vented out the side with no way of closing it, so we fit something to block it on the inside and hold it on with Velcro.
Geoff
I designed my kitchen with a 2 burner gas top and a microwave/convection oven above the burners (no stove).  The micro/convection oven has its own exhaust vent that picks up the burner fumes so I made a plenum that directs the exhaust out the back of the micro/convection, down a passage to the floor where it exhausts over the fuel tank bay.  I used standard size aluminum flex vent hose for a house kitchen vent.
No hole in the roof or side of the bus.  I just put a vent screen on the discharge to the bay to keep the critters out.
I don't know anyone else that has done it this way, and the vent pulls 100% of the heat and smell out of the bus when using both burners or the microwave/convection oven.
--Geoff
Geoff
'82 RTS AZ
I use a non vented hood above my stove. With the fan on, it just blows the hot air straight into the room. Then directly above the hood is a Fantastic vent. It works so well, I've repeated the same thing on my bus. I did not want any type of vent on the side wall. Good Luck, TomC
oh my   ;D.
my setup is the same as Tom's. it does work really well.
sledhead
1" aluminum heat shield ( black ) under the rg upper with 3  led puck lights in it . Fantastic fan as close to cook top right in front of upper cabinet works great
dave , karen
LowTide
My set up is the same as Toms' too! The fantastic vent works really well ;)
Mike and Lori
Sunny Phoenix Arizona
"1973 MCI MC-7 Challenger"
"Just Misbehavein' "
"A nation of sheep helps breed a government of wolves"
Seangie
Non vented hood with fantastic fan.  Fantastic fan is awesome.
1984 Eagle 10S
www.herdofturtles.org
'Cause you know we,
Driving through the night
To that old promised land'
Flight102C3
Sorry! I posted than had to leave. I will read all of them will respond. Thanks to all
scanzel
Our coach is side isle configuration with a full bathroom, 4 burner 24" Italian made stove with oven and broiler, over stove microwave with direct vent above to outside with vent facing rear so as to not act like an air scoop. We like to cook so that is why we went this way.
Steve Canzellarini
Myrtle Beach, SC
1989 Prevost XL
Dave5Cs
We just open the window behind the stove top and have a small WM fan we turn on below the cabinet above the stove/oven combo. We have a fantastic in the bath that we also turn. Works great.
Dave5Cs from Galaxy S III
Flight102C3
Sorry, I'm back! Thanks for the info I'm going ventless with a fan above. I think this will work for me. Thanks again!
Geoff
I am sure someone out there has had to clean the screens on a stove hood or microwave oven, and has seen how much grease gets sucked into those filters.  Well, if you are depending on a Fantastic fan or other to suck the stove/burners greasy air out the bus you better not cook too much or your ceiling will will absorb that grease.  I have an Ozite ceiling and can't wipe it clean.  Better to to take the extra time and blow the cooking exhaust out through a hose-- I went with a floor exhaust into the fuel tank bay so no problems with greasy fumes.
--Geoff
P.S.  Did I forget to mention the smell inside the bus without proper cooking ventilation?  It sticks to the ceiling and walls and makes your bus stink after a while.
Geoff
'82 RTS AZ
