The March Issue of BCM has Started Arriving
Started by Gary Hatt - Publisher BCM, March 12, 2014, 10:16:08 AM
This issue contains the following articles;
        Upgrading Bus Headlights – Jim Shepherd
        Simple Fix For Leaking MCI Air Suspension – Tuck Friar
        Easy Access Wiring & Plumbing Channels – Gary Hall
        Call of the Eagle – Cary McCart
        2nd Annual Dam Rally – Tami & Tom Vannozzi
        Rebuilding A Bus From The Tires Up – Steve Gains
        Drawer Guides – Dave Galey
The Digital Editions of the March issue contains nine additional pages of photos of the Dam Rally and more photos of The Call Of The Eagle that would not fit in the Printed Edition.
The Digital Editions of the magazine, which include both the E-Mag and the Online Editions, also include a feature such that if you are connected to the internet and you click on most of the photos, a larger, higher resolution of the photo will open. If you click on the photo again it will enlarge even more so you can see the finer detail. If the photo is larger than the screen, you can pan around the photo using the horizontal and vertical scroll bars on the right and bottom of your screen.  If there are no scroll bars on the right and/or the bottom of the screen, it is already at its maximum size.  To close the photo, simply click on the "X" in the upper right hand corner.  Higher resolution photos are not an option in the Print Editions as the size of the PDF would be too large to be accepted by most email systems.
Anyone with only a Print Subscription can choose the E-Mag Edition Add-on that is sent to your email address or the Online Edition Add-on which you access by logging in at www.BusConversions.com/magazine/ to read or download for a very reasonable price based on the number of months remaining on your current subscription which is printed on your mailing label.  To add either of these editions to your current Print Subscription, simply click the applicable link below and choose the number of months remaining on your current subscription from the drop-down list.   Both the E-Mag and the Online Add-ons cost the same and both are dirt cheap, starting at only 85 cents per issue.
E-Mag Edition:  http://www.busconversions.com/store/product_info.php?cPath=51_53&products_id=241
Online Edition Access:  http://www.busconversions.com/store/product_info.php?cPath=51_53&products_id=240
If you would like a new subscription to the magazine, simply click on the following link and choose the delivery method you are interested in as well as the duration.  If you choose the Print Edition, there is also an option to choose either Digital Editions Add-on for a very reasonable price starting at only $5 per year.
http://www.busconversions.com/store/index.php?cPath=51_55
We hope you enjoy this issue of Bus Conversion Magazine.
If you have any questions regarding adding the E-Mag or Online Edition to your current Print Subscription, please contact webmaster@busconversions.com
If you have any questions regarding the Forum, please contact ForumAdmin@BusConversions.com
If you have any questions, suggestions, or comments about the magazine itself please contact Editor@BusConversions.com
If you have any questions about your subscription please contact Linda@BusConversions.com
If you have any questions about anything else, contact me at Gary@BusConversions.com
Gary Hall – Publisher
Mike Sullivan – Editor
Phil Lyons – Forum Admin
Linda Sohn - Subscriptions and Accounting
(657) 221-0432
1999 Prevost H3-45
