730 allison
Started by jimsflx, January 20, 2014, 02:40:57 PM
jimsflx
any body have one? thanks jim for sale
jim&roenie seagraves sebring fl. 4106-3083
Don and Cary here on the board had a rebuilt 730 for sale check with them is yours bad or you looking for one to install
jimsflx
thanks Clifford we need one to install going to get rid of the 4 speed thanks jim
You better start looking for the heavy @$# flywheel and drive for the install they are getting hard to find for the 8v71 fwiw here anyways
Barn Owl
Long for the days when Nimco had them for $1200. It is strange seeing people having to search for them.
Jim -
Did your coach belong to Bob Hamilton in upstate New York?
He's the only one I know of that had a '65 '06 which was originally purchased by Vermont Transit Company (in April of '65 as fleet number V-760.)
Cary and Don
The one we have is a V731. Our understanding is you can convert it back to mechanical pretty easy.  We were thinking of replacing the V730 with the push button V731 at one point.
Don and Cary
1973 05 Eagle
Neoplan AN340
jimsflx
rj yes it was bob bus he did a nice job on it I love it thanks jim
jimsflx
cary&don thanks for the reply. a friend of mine has a 731 but I do not know how to turn it back to a 730 thanks jim
Barn Owl
Bill Gerrie, who can be found on the BNO board, is very knowledgeable about the differences, and what is required, to switch between a v731 and a v730.
DMoedave
wow, so close! he was parked behind you just a little south at Arcadia! I just met you both this year.
we love our buses!!! NE Pa or LI NY, or somewhere in between!
The 730 is basically a 3 speed 740 all the valves and clutches are the same in both and the 731 uses solenoids to direct the flow of oil same transimmion except for the valve body  fwiw
Switching to a V731 electronic will involve wiring and changing the shift pad. Granted the V731 will shift smoother, but the mechanical V730 is so reliable, I would keep it mechanical. I have the V730 and am very pleased with it. Just wish Allison had made a 4spd version. Good Luck, TomC
Cary and Don
We had planned on the change to get rid of that shifter.  It seems like it would be easier to install the V731 with a wiring harness than a V730 with the sifter tower and shift cable to the rear. Like Clifford said, mechanically,  they are the same.
Don and Cary
1973 05 Eagle
Neoplan AN340
Yes, mechanically they are the same. I have the long cable shifter, and you get used to the play in it. The electronic sound good on paper, but have an electrical problem that requires towing and repair and all the savings go out the window. Stick with the mechanical. Good Luck, TomC
