Interior Ceiling Covering ? What have you used.
Started by scanzel, September 18, 2013, 09:40:24 AM
scanzel
My wife and I are discussing ceiling covering and we both cannot agree on what to use. She says just patch screw marks and paint, I want something more attractive. What has everyone used. We do not want vynal covering.
Steve Canzellarini
Myrtle Beach, SC
1989 Prevost XL
Backsplash sheets from Bontragers.
Sent from my iPhone using Tapatalk. Clumsy fingers may contribute to mistakes.
Iceni John
Has anyone here used 1/4"-thick cork?   It comes in 36" or 48"-wide rolls, and it has some slight thermal and noise insulation.   I'm thinking of it as a possible contender, but I would paint it satin white.
2kW of tiltable solar.
Lin
What is the material that is currently on the ceiling?
busguy01
Ozite (Spelling?) I used a light crem white contact cemented over 1/4" luan. Lasted for years and looked very nice. Still have a bunch new on roll if anyne interested.
JimH
Started with nothing - still have most of it left!
1963 Eagle 01 with Detroit 60 series done (Gone-sold!)
MCI EL3 in progress. raised roof & Slides
2009 Revolution 42 Sticks and staple
Summer - Yankton, South Dakota
Winter- Sebastian, Florida
Quote from: Iceni John on September 18, 2013, 11:51:04 AM
We put cork on the cabin ceiling of a boat once and it worked really well - completely solved the condensation that would sometimes form, and it was always warm and pleasant to touch (not cold and hard). I thought it might be prone to getting damaged, but it really wasn't. We coated it in a clear varnish or some sort so it was left in is natural colour. I'm not exactly sure what kind of varnish we used - it wasn't regular yacht varnish but something much thinner that penetrated the cork a bit I think. Possibly some proprietary product sold specifically for use on cork.
PS. Those 'backsplash sheets' - what are they made of - some sort of moulded plastic or pressed wood/fibreboard type thing? I bought some artificial suede fabric (like Alcantara but without the brand-name) for my ceiling, but it'll be a long time before I'm ready to fit it so I'm still open to alternatives
Jeremy,
The backsplash sheets are a very dense fiber board (hard as rock). The side you see is coated in a plastic almost like vinyl. Water proof and wipes clean. We painted it with an interior latex.
    You said that you didn't want vinyl but I used the hide of the elusive Nauga on both my ceilings and it came out looking really nice.  Just my way.   ;)
Quote from: Oonrahnjay on September 19, 2013, 04:43:38 AM
I once hunted Nauga.  Here's the one I had mounted:
lvmci
hi scanzel, this diamond pattern ceiling was a pro conversion from 1986, its CLEANABLE, insulates, has held up all these years in the southwest heat and I think is attractive, lvmci...
MCI 102C3 8V92, Allison HT740
jmblake
Scanzel, We used a 5/16" oak tongue and groove bead board, they are individual boards about 3 1/2" wide put onto plywood that is screwed to the ceiling members. It gives it a warm look. Jason
http://s630.photobucket.com/user/jmblakebus/media/100_1412.jpg.html?sort=6&o=52
http://s630.photobucket.com/user/jmblakebus/media/100_1410.jpg.html?sort=6&o=56
Cary and Don
We have two ceilings with different materials.  They both have their advantages.
The 4107 has a commercial fabric wall covering that looks like a really thin carpet.  It is really warm with a little insulating value.  It takes away that tin box sound and makes for really nice surround sound when the tv is on.
The Eagle has a laminate ceiling.  It is part or the lighting system.  There are strip lights along the top of the side walls that point up and reflect off the ceiling for a really nice defused light.
Don and Cary
1973 05 Eagle
Neoplan AN340
robertglines1
Maybe you should just paint it like she suggest and use it for awhile and travel to bus get together  and look at others. Your prevost has some ceiling foam but the ribs to ceiling alum do transfer a lot of heat and cold--just shoot them in the sun with a IR gun.   I found  20 degree difference from where the ribs are to 6 inches away from them..I added another 1/2inch of foam over entire ceiling to stop this toaster heat transfer effect . Or ice box coil cooling effect.  then covered with luan sheet.  I used the dreaded marine vinyl..(ugh I know)  but you can do as you like.  Car headliner material  ,  slick plastic  ,extruded  foam,  Upholstery fabric, stucco. drywall.  Whatever.. I screwed  thru luan  thru foam board to steel ribs to attach base to attach any thing you desire to ceiling.   Do it your way!!!    Go to Action Upholstery Supply for Ideas.    They supply the boat and auto industry.    Bob
treeplanter
I am in the process of installing red cedar milled down to half inch thick by three and a half sealed with multiple coats of lacquer nailed and glued to plywood, it's easy to work with and has a beautiful color and is very light weight.
Timothy
1/8" birch covered furniture grade plywood-will conform to the curved roof and is formaldehyde free. Then painted gloss white with 2" wide gloss varnished oak strips over the screw holes, with the oak strips screwed with brass colored square hole finish screws. Simple, and can access (take apart) anytime if needed. Cleans easily too. Good Luck, TomC
