LuberFiner?
Started by Jerry W Campbell, August 07, 2013, 03:27:30 PM
Jerry W Campbell
Hi Friends,
   I'm running a 6-71N It has a Luberfiner bypass filter. It holds almost 3 gallons of oil.
I have changed the oil and filters every 6000 miles for the last 10 years.
I'm thinking I don't really need it.
If I take it off, can I just plug the holes and forget it?
Jerry
Endeavor to Persevere
Uglydog56
You certainly can.  I would leave it though, and just not change the filter as often.
Rick A. Cone
Silverdale, WA
66 Crowny Crown "The Ark"
Jerry W Campbell
Thanks for the advice, Rick.
Jerry
When I turbo'd my engine, we disconnected the luberfiner since we needed the extra oil pressure for the turbo. I used to change the oil every other year, now just change it every year. Good Luck, TomC
I would remove the Luberfiner the 3 gals extra is a over kill for 6-71 anyway the 1 qt size is enough for a 6-71 if you want a by pass filter
