Bus Trip/Progress
Started by buddydawg, July 23, 2013, 04:17:23 PM
buddydawg
Hey all! Just arrived at Short Stay Recreation Area for a weeklong camping trip.  It was a 178 mile drive with no issues, bus ran great.  Outdoor temps were in the low to mid 90s today and my two 12K BTU mini-splits kept the bus temps in the mid 70s.  The campground here is relatively muddy due to the constant rain for the past month but we found a site that was dry enough.
My new method for bus renovation motivation is to complete a project before every trip.  This time I addressed my windows.  I was tired of fighting with the old sliding windows, which were only good for letting water in and my air conditioning out!  I stripped the old windows down to the frame and replaced the sliders with one single pane of bronze Plexiglas.  Combine that with some new outer seals and it appears that I have a new set of leak-proof/draft proof windows.  So far I am pleased with the results, the inside temps were stable and the ride was noticeably quieter.
1972 GMC T6H-5308A #024
1984 Eagle Model 10
Brandon Stewart - Martinez, GA
buddydawg
Window Close-up
1984 Eagle Model 10
Kevin
Lookin' SHARP!!!
Very nice, classy-looking coach you have there! You're doing right by it.
Enjoy your adventure,
Kevin
Quartz Hill, CA
"To the gov!!!"
buddydawg
Here is another shot from the inside.  I am jacked about these windows.  I had suffered with the old windows for years, I wasn't sure I'd ever come up with an affordable solution. It was not a lengthy project, it  I had them all done over a weeks time.
1984 Eagle Model 10
muldoonman
very clean and nice coach there Buddy!
pabusnut
Bandon,
Veeery Nice!  ;D  I never got anything that nice in my '5301 !  Decided if I was re-doing, I'd start w/ something that has more storage.
Steve Toomey
PAbusnut
Steve Toomey
PAbusnut
LowTide
You did a knock down job with those, they look sharp!
I am curious as to how you got the plex to stay in the frame and your selection of seals. Did you use the factory rubber seals or did you have to get creative when it came to replacing the seals or rubber? Also, what thickness plex did you use?
The only issue I would worry about is the plex scratching, so be carefull when wiping them off....I am sure you already know this.
Mike
Mike and Lori
Sunny Phoenix Arizona
"1973 MCI MC-7 Challenger"
"Just Misbehavein' "
"A nation of sheep helps breed a government of wolves"
buddydawg
Thanks for the compliments.
Mike
The old frames come apart at the top, I just removed the center hinge and ground out a small weld.  The windows have two tracks for the old slider windows to ride on.  The inside track in just over 1/4 inch from the inside part of the frame.  I made a 1/4 inch plywood template and adjusted it for a snug fit.  I applied a bead of sealant in the grove and installed the 1/4 plexi, I used the center hinge to rejoin the frame.  I also used a few bar clamps for some pressure while the sealant cured.  Once cured I rewelded the frame and put a bead of sealant on edges of the plexi to the frame.  I replaced the outer rubber channel seal which goes on the outside of the frame to the exterior of the bus.
I will take a few closeup pics later and add them.
1984 Eagle Model 10
OneLapper
OneLapper
1964 PD4106-2853
www.markdavia.com
