front right side axle spindle ,seals and bearings, tag axle
Started by JROD, June 09, 2013, 02:03:47 PM
JROD
Hello not sure if anyone received prior message. I took mover project about 12 yr.'s. ago when my father passed.  Just recently rebuilt 8v-92 with turbo, new air bags installed ,
studs installed for aluminum rims. Unfortunately on my travel's around the area of Fontana Ca. a bearing went out due to seals not changed out by mechanic of a friend of mine. Took rim off to find
bearing welded to axle spindle. Does anyone know where I can pick up reasonable and  along with outer and inner bearing .
[JROD] 1:53 pm: I have part #'s for bearings of tag and front axle but not for drive axle. Also I need seal part # for all axles. Can anyone help. Where other then MCI getting parts?
JROD rang the bell
tekebird
Sam Caylor 1-785-878-3406 he should have a used spindle and will give you the parts numbers for aftermarket seals and bearings
JROD
Quote from: tekebird on June 09, 2013, 03:22:22 PM
what model bus  serial number will help as well.
Sorry, you all need this pertinent info.
1978 MC 8
SERIAL # S13276
