Non standard use for coach mounted tow bar
Started by travlinman, May 08, 2013, 01:36:29 PM
travlinman
Hey Guys,
Not a bus question but given the bus nuts way of working around problems I thought I would try here first.
So, I'm helping some friends move this summer and I would like to bring my truck so I have a way home. I have a roadmaster coach mounted falcon 2 tow bar. I'm wondering if anyone has ever mounted a ball receiver on the front of the bar where it inserts into the hitch?
The moving truck they are using has a two inch ball and wiring all set up so half the battle is already done.
Thoughts??
TM
Steve & Kristen Full time nomads since '06 - PD4106-674  8V71/V730
This bus is for sale - https://gm4106.wordpress.com
Lin
I am not sure I understand.  Is the plan to use the hitch backward?
wildbob24
TM,
I guess you could weld one of these: http://www.northerntool.com/shop/tools/product_200414748_200414748
to one of these: http://www.northerntool.com/shop/tools/product_200442400_200442400 to do what you want to do.
The main problem I see (assuming a good welding job) would be having 2 pivot points between the bus and the toad. Might make for some interesting tracking.
Bob
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
PD4106-2546, 8V71, 4sp
Greenville, GA
gumpy
If you want to attach an A-Frame hitch to a ball, you will have to remove the square receiver insert portion and permanently attach a ball hitch.
You will have to remove the pivot point where it attaches to the ball hitch. Only one pivot point, and that's the ball.
Suggest you simply build a rigid A-Frame that attaches to the two points on the truck and has a fixed ball hitch on the other end.
travlinman
Lin - I'm not planning on using the bar backwards. My thought was to bolt a coupler to the front of the tow bar where it inserts into the receiver on the bus.
Bob - I like your take on the idea with the receiver tube added to the mix. As far as the two pivot points go, I will need to give that some thought. It could prevent the truck from following the moving van!
What else am I missing?
Looks like gumpy filled in the last piece of the puzzle while I was typing. I guess two pivot points are a bad idea. I was thinking it would work like a tandem semi, but perhaps not.
TM
jjrbus
  Got a HF nearby or enroute?    http://www.harborfreight.com/catalogsearch/result?q=tow+bar
  Sell it when you get home.      Jim
