Started by Nick Badame Refrig/ACC, April 05, 2006, 06:44:52 PM
I would like to see all members bus pictures HERE!
I think it would be nice to have one place for member's busses!
Folks, only BUS pictures. limit 4, and a brief message about your bus. Thank You!
If you have any questions on how to post pics, please view the numerous threads on the subject POSTING PICTURES!
Or you can e mail me, or Plil Lyons
_____________________________________________________________________________________________
1989 MCI 102C3-8v92t ht-750   50a all electric,
side isle design, custom built laminate cabnitry,
corion tops, marble floors, ultra suede headliner,
ultra leather seating, pioneer navigation, xm radio,
pioneer audio, KVH in-motion sat, 3 flat tv's, rear ent,
2 custom central hp's in bay, duel pane Motion windows,
Proheat X-45 with hydronic heat coil mated to HP's
magnum opus comode, 38"custom corner shower,
real pex plumbing, tanks 105-105-40gal, Frigidaire side by side ref,
dometic conv. micro, Dometic central vac, 12.5 onan diesel gen,
840ah batt bank,  sine wave Xantrax RS 3000 network inverter,
hub king covers, 24'x10' A&E lat arm automatic awning.
custom 12,000# hitch, r&m glass cap & fenders,
smooth sided,  STARJET PAINT By Dick Cahill
BillC
Bill and  Patricias     1983  Eagle    10s
1983  Eagle  10 S
JimC
OK
Jim & Linda Callaghan
JimC  Wisconsin
4106 - 8-71/730
Oconomowoc, Wisconsin
between Milwaukee & Madison
DC_Bus_Nut
Here she blows.
1984 MC-9
Converted in 2000 by Virginia Custom Coach
6V92 DD
15 KW Kubuta Genny
110 Fresh/110Grey/60 Black
Calypso Style interior.
U style rear sofa that converts into King Bed
2 Custom Couches in front salon that convert into beds
2 Barrel leather chairs & Leather Pilot and Co-Female Pilot Seats
3 Roof tops with heat (getting ready to be painted blue).
Tile/Berber Carpet combos
plyonsMC9
JackConrad
OK  Jack
tomhamrick
Let's see how this turns out.
Tom Hamrick
1991 Prevost H3-40 VIP
1981 Eagle 10
Forest City, NC
bigtim44
Here it is again  ;D
Basalt Colorado
1986 TMC 102A3,6V92,Auto 740,conversion in progress.
http://redbusconversion.blogspot.com/
rv_safetyman
Wow, those are some beautiful buses.  I kind of hesitate to post a picture of my Plane Jane Eagle.  As most of you know, I have spent a lot of time on the mechanicals and getting the systems working.  Now I will spend some time working on the exterior.
Jim Shepherd
Evergreen, CO
DrivingMissLazy
I think I posted this somewhere else but do not remember where. 1980 Eagle 10. 8V92TA
Driving Miss Lazy.
NewbeeMC9
Not smart enough to post  Tried again,   Hope Dallas dont think it's his 'cause his names on it! :D
here's a link
http://pg.photos.yahoo.com/ph/newbeemc9/my_photos
BJW
Hey Guys,
What a great idea to have one place to file pictures of buses.  Here's "Gus the Bus" as he was and how he is today....Let me know if I can answer any questions....
BTW I love ALL of the buses... They're great!  :)   I look forward to more pictures from other members soon...
BJW
Gus the Bus
Federal Way, WA
Eagle
1985 EAGLE Model 10
6V92TA
Allison HT740
Chris 85 RTS
1985 GMC RTS II 40x96 6V92TA MUI V731 IFS
David Anderson
SPECIFICATION SHEET FOR HOUSTON METRO EAGLE 10
Manufacturer:  Trailways Mfg Co. Brownsville, TX
Year built:  1985
Conversion done by:  David Anderson
Years converted 2000-2003
Vehicle weight: full fuel and water 36,100lbs.  Manufacturer's maximum GVW 38,700
Fuel tank:  275 total gals, 150 gals main, 125 gals aux
MPG 6.2
Engine: DD 6V92T silver series
Transmission: Voith 4speed electronic control automatic with 3 stage retarder
3.38 Rockwell rear end with Drop box
Radiator: 7 row heavy duty with mister
Radiator fan:  16 blade European Composite variable pitch (bought from Goodson Bus Sales)
Oil pan heater: 1000 watt 120v stick on surface mount
Engine preheater:  Webasto diesel fired
Length:  40, width 8, Height 12'6" to top of air conditioners.
Tires: 24.5
No. of steps: 5
No. of Luggage compartments: 1.5
Raised Roof: 7"
Solar power:  no
Outside colors:  urethane white base coat, maroon, blue, and gray accent stripes, with           clear coat .  Roof is covered with Kool Seal.
Hitch type: heavy duty, fabricated locally
Gauges:  VDO---tachometer, oil press, oil temp, tranny temp, water temp, voltage, 2 fuel, 2 air, turbo, and Dixson speedometer with marked shift ranges to match the Voith transmission
Batteries: 3 Sam's HD truck batteries for bus batteries
Electrical system: 12 volt 330 amp Niehoff  alternator
Inverter: Trace SW2512 (Wrico)
Generator:   Kubota 13KW  (Wrico)
Steering: Ross power steering  (Eagle factory installed)
Suspension:  B.F. Goodrich torsalastic
INTERNAL EQUIPMENT
House batteries: 8 Sam's golf cart 6volt batteries wired for 12 volt, 880 amp hours
12volt house, branch circuitry: 36 circuits, automotive type push in fuse holders ranging from 3 amp to 30 amp circuits
Electrical:  50amp 240v main, 50amp 240v genny main, with auto transfer switch  (Wrico)
Branch panels:  two, one fed through inverter, one that bypasses inverter
Merge Switch: Automatic merge switch for house batteries to bus alternator (Wrico)
Automatic generator start switch:  Genmate, from Wrico
Fresh water tank: 130 gals (Ardemco)
Gray water tank: 2 tanks @ 48 gals each (Ardemco)
Black water tank:  55 gals   (Ardemco)
Tank materials: polyethelene
Water pump: Sureflo with bladder tank (Camping World)
Water heater:  Seaward Model S1100, 11 gallon electric with heat exchanger for use with Webasto heat (Wrico)
Plumbing material used: PVC for drain and waste, CPVC and Type L copper for water delivery.  3/8" black iron pipe used for propane
Propane capacity: 5 gals (Camping World)
Stove:  Magic Chef 3 burner with oven (Ron the Busnut)
Refrigerator:  E-Wave 10 cu ft 110 volt (Home Depot)
Microwave:  1000 watt (Walmart)
Dishwasher: 18" GE (Ince Dist Co)
Sink: single bowl acrylic  (Lowe's)
Toilet: Thedford (Camping World)
Shower:  38" neo angle (Home Depot)
Bath vanity: Cultured Marble Bowl (Mission City Marble)
Special kitchen features: Halogen lights under cabinets (Home Depot)
Custom hinged counter top over stove (Home Depot).
Courtesy rope lighting under cabinet toe kick area (JC Whitney)
Air Conditioning: 3 Low Profile Ducted Coleman 2 speed Rooftop units (Wrico)
Heating: Webasto DB2010 diesel fired furnace with zoned fan forced and radiator type heaters throughout coach (Wrico)  Also, a Webasto 40,000 BTU heat exchanger installed on engine for block heating or heating water while on the road.  (Wrico)
Windows:  Peninsula Glass double pane RV slider windows
Walls: bedroom has carpet over ½" plywood.  Bathroom has marble hardboard, kitchen has wallpaer, lounge has carpet.  (Home Depot)
Ceiling: Marine vinyl glued to ¼" luan plywood, screwed to a suspended metal frame on one foot centers
Type of wood:  substrates-1/2" BC plywood and ¼" luan.  Cabinets: Walnut hardwood and Walnut plywood
Counter tops: Vanity and office desk is cultered marble.  Kitchen and booth is Formica
Floors: Carpet in bedroom and lounge. Peel and stick vinyl tile in galley and stepwell (Home Depot)
OPTIONS:
TV: Goldstar 25" VCR: Panasonic  (Walmart)
Stereo: Audiovox (Ron the Busnut)
Back up Camera:  Remington Security system with 2 cameras rewired to reverse image  (Sam's Club)
Twin beds pull together to make a queen bed (home made)
Window Coverings: Bali blinds (Home Depot)
Furniture: Flexsteel (Bradd & Hall)
Turbo Max vent  (Camping World)
Heavy duty sound insulation in Genset compartment (Wrico)
Pancake air compressor on board  (Harbor Freight)
Built in tool chest (True Value Hardware)
