4106 Rear Wheels
4106 Rear Wheels
Started by BUS COMMANDER, March 03, 2013, 02:07:49 PM
BUS COMMANDER
Trying to remove an inner rear wheel to repair an air bag. The inner wheel is ceased into the drum,  any  tips on getting it off? Thanks.
Wes Jackson
put the nuts back on, just ever so loose, and drive the coach for and aft and nail the brakes. The weight of the coach is stronger than we can swing a sledge, and no rebound to worry about.
wg4t50
buswarrior is correct, leave the inner nut about half turn loose or you could also hit the tire with a heavy sledge hammer, not a little ball pean type, not rim just the tire, and hit it hard.
but the easy is loosen and drive around the block
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Raymond smith
i have rolled the outside tire into the stuck inside tire  Raymond
1957 4104-3632 & 1989 mci 102c3
If it doesn`t fit properly the first time, Get a bigger hammer
