Magnetic pump guestion
Started by Larry B, February 24, 2013, 06:46:19 PM
Larry B
  I picked up a magnetic pump ($10.00 invest) a while ago from a salvage yard and finally decided to put it in bus to help pro heat and engine water pump circulate glycol through house heating system. Pro heat is located in engine compartment, long way to bus front for pro heater. When checking pump over found crack in plastic housing that holds donut shaped magnet to 24 volt motor. I have a small lathe and a piece of 3" brass in my junk. My first question to those that understand electic motors and magnetisum a lot better than myself is will this pump still work properly with a magnetic holder made of brass?   I would prefer to power this motor off my 12 volt house battery.Second question is what sort of device do I need to get 24 volt off 12 volt battery. Motor takes 5 amp to  start and 1 amp to run on 24 volt(with no load or magnetic drive mounted).  pictures show crack in holder  (between black pen marks)Thanks
           Larry B
1977 MCI-5B---
8V71- 4speed man
Hi Larry,
I have played with them alot in the past and I didn't always have luck getting them to
work properly once the bakelite cracked. The magnet has to be in the proper position
or the armature will not react right and sometimes not spin as fast as it should, if at all..
Housings are not too expencive and come in a kit form with "O" ring.
Changing a 24v to 12v is all in the windings if you know how to do that! Pulling 12v's from
your 24v bank can be done through your 12v post off a Vanner.
Good Luck
TedCalvert
24 volt motor from 12 volt battery would be a problem
pvcces
Hi,Larry B.
The name of the device you are looking for is "boost converter". An example is 151000932032 on eBay. I think you can turn something up if you look around. The price is right, if it will serve your needs.
There was a Vanner unit listed, as well. Watch out for idle current; you need to have a way to shut it off.
Good luck.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
