Mobile Water Softener or Reverse Osmosis or Something?
Started by Scott & Heather, February 12, 2013, 07:15:15 AM
I have scoured various threads on this subject and most seem to date back to 2008. I know water quality management technology changes constantly. We are now parked and will be parked for 1 year at a spot that has some super hard water with lots o iron in it. We've been here 4 days and already have this:
Sorry for the nast picture. That toilet is sparkling. We keep it that way...with the exception of the instant iron buildup. This is starting to seriously bother us. We need a solution. I've checked out "On-The-Go" and RV Water Filtration Systems mobile water softeners. They look great, but I want another opinion. We have an RO system for our refrigerator drinking water...but that system is turned off while we're deciding how to soften the water. I don't want to clog the membranes. We are not connected fulltime cause it's winter...so we fill our 100 gallon fresh tank every few days from a hose that we retract. So any solution that requires major backwashing is not practical for us. What say you? Nick, can you chime in? I know you have some cool something on your rig...Everpure???
wagwar
This could be a solution:
http://doultonusa.com/
I have one of their carbon filters and ceramic filter on my incoming water system. I've had no problems with it and it supposed to purify the water.
Just got off the phone with a gentleman at Doulton...he seemed confused and not super studied on their systems. He at first told me the RIF-10 system would work for us...then he said since we have Iron we needed to oxidize it before the water went through the RIF-10 system...so I asked if that meant we needed a water softener...he said "no" just buy the FSC3 unit which provides saltless scale removal and water conditioning. So I said "that's all I need? Those two units?" then he said "no" the FSC3 won't remove iron...so I said "then I need a water softener?" he said "no"...now I'm on hold.
Rick 74 MC-8
Scott
Probably the easiest Way to handle things is just install a small filter with a polyphosphate cartridge In most cases that will bined the iron so it doesn't cause a problem. What I think the guy from Dalton was trying to explain Is ferric or ferrous iron. If the water is clear the iron is dissolved in the water and can only be removed with a water softener ion xchange ( clear water iron) if the water is orange it can be filtered out with a filter so to cover both put a filter and then followed with a polyphosphate in most cases that will help a lot
Rick
Rick 74 MC-8
PCC Series cartridges contain foodgrade
hexametaphosphate that
dissolves slowly in water to inhibit
scale and rust build-up.
This type of treatment is
recommended for use with ice
machines, coffee and vending
machines, food service equipment,
water heaters, air conditioning
equipment and many other types of
water processing equipment.
To best meet your needs, cartridges
are available in four feeder sizes and
all materials are FDA grade.
They are effective for treating scale,
corrosion and iron problems for up
to six months at various flow rates
and feed concentrations.
The PCC212 and PCC218
cartridges are designed to fit #10
Standard or Slim Line® filter
housings.
The PCC106 is an insert element
that is placed in the center core of
the cartridge. It is designed for use
with standard 10" and 20" radial
flow, sediment and carbon block
filter cartridges.
PCC SERIES HEXAMETAPHOSPHATE
CRYSTAL CARTRIDGES
• Effective for treating scale, corrosion and iron problems
• Ideal for a variety of food service equipment, as well as other types of water processing equipment
PCC1 PCC212
PCC218
PCC106
PCC SERIES
CRYSTAL CARTRIDGES
502 Indiana Avenue • P.O. Box 1047 • Sheboygan, Wisconsin 53082-1047
Customer Service: 800-645-0267 • Fax: 888-203-7361 • supportspecialist@pentekfiltration.com
International: 920-457-9435 • Fax: 920-457-2417 • international@pentekfiltration.com
© 2004 Pentair Water Treatment www.pentekfiltration.com Printed in U.S.A. 01/04 310085
PCC SERIES
Hexametaphosphate Crystal Cartridges
CAUTION: Eye irritant. Contains sodium calcium hexametaphosphate. Avoid contact with eyes. In case of eye contact, flush with water for 15 minutes, get medical attention.
Keep out of reach of children.
WARNING: For drinking water applications, do not use with water that is microbiologically unsafe or of unknown quality without adequate disinfection before or after the system.
NOTE: PCC212 and PCC218 cartridges are not recommended for main line water applications with flow rates exceeding 3.0 gpm (11.4 lpm).
NOTE: With steamers, the water should be flushed daily.
CAUTION: Do not use this cartridge on water that will be carbonated.
Materials of Construction
• Filter Media Food Grade Polyphosphate
• Shell Polypropylene
• Post-filter Polypropylene (PCC212 & 218)
• Gasket Buna-N (PCC212 & 218)
• Temperature Rating 40°F to 100°F (4.4° C to 37.8°C)
Cartridge Specifications and Performance Data
Maximum Initial ΔP (psi)
Model Dimensions @ Flow Rate (gpm)
PCC1 2-7/8" x 9-5/8" Up to 5 gpm
(73 mm x 244 mm) (19 L/min)
PCC106 1-1/16" x 5-7/16" 1 to 1.5 gpm
(27 mm x 138 mm) (4 to 6 L/min)
(for insertion in center core of open core cartridges)
PCC212 2-5/8" x 9-3/4" 1 to 1.5 gpm
(67 mm x 248 mm) (4 to 6 L/min)
PCC218 2-5/8" x 9-3/4" 1.5 to 2.5 gpm
(67 mm x 248 mm) (6 to 10 L/min)
SCALE: Hardness particles are kept separated so they cannot
precipitate and form deposits when heated. Maximum hardness
15 gpg.
CORROSION: A protective coating is formed on all metal
surfaces, safeguarding against acidity/alkalinity, hardness,
chloride and other factors which effect the corrosion of water
equipment and pipes. pH range 6.5 – 9.0.
IRON: Dissolved iron, up to 1 ppm, is kept suspended in
solution (sequestered), preventing dissolved iron from
precipitating, which would cause staining and discoloration.
Lin
Rick, that cartridge may be just what I want to control mineral deposits from using a mister.
Wow Rick...nice stuff there. I read somewhere this stuff isn't for consumption? Or since it's food grade it's ok? Any links to websites where I can buy this system?
The WaterBoss from HD for 400 bucks works amazing it does it with a sand filter I just install one in my house after the 1500.00 so called iron filter won't work first time have had iron free water in years
Tell me more cliff... You use this on the bus? I thought there was a huge amount of backwash with that system?
Sent from iPhone via Tapatalk
Lin
That filter cartridge is available on Amazon for around $50.  I think it says that it fits a standard #10 filter housing, whichever one that is.
Quote from: Scott Bennett on February 12, 2013, 06:24:41 PM
I had a WaterBoss water softener in my house until it failed.  The backwash uses quite of water.  I also had problems with dark yellow water after every regeneration that took a lot of water running to get rid of.
Seangie
Scott,
I am setting up our bus with 2 filter canisters before the fresh water tank. If we use city water it will run through the filters before going into the bus and if we want we can filter into tank and then through the filters again as it comes out of the tank into the house system. (Double filtered...unnecessary but makes the wifey happy)
We can choose whatever filters we want for the canisters.  I have found that there are many different filters out there and choosing the one you need depends on what you are trying to filter.  I have also found that it is very near impossible to "soften" water through simple filters only without processing the water.
The best filters we have found for taking nasty water and turning it into drinkable water are the doulton ceramic filters.  These are the same as the ones used in the Big Berkey water filter system.  The only downfall to these is that they work best at a very slow rate (3gpm or so). These ceramic filters are reuseable and supposedly last for life although they need to be cleaned often. We are going to use a 3rd ceramic filter on a seperate water line for drinking water only that runs to a water dispenser at the kitchen sink.
Rick Dahl from http://www.rvwaterfilterstore.com/ gave us a bunch of great information about the filters and RO systems.  Email him from his website and he will get you some good information about solutions and what is available out there on the market. I have not purchased anything from him and am in no way associated with him or his website.  He was very helpful with no sales pitch and no expectation of us purchasing from him.
www.herdofturtles.org
1984 Eagle Model 10S
'Cause you know we,
Driving through the night
To that old promised land'
Good info Sean. Thanks! I have a couple of options and I'll see what I can do about all of this. I do think a small onboard softener should be part of the plan
