Aluminum Alloy used for GMC 4106 skins?
Started by Darkspeed, December 30, 2012, 07:37:37 AM
Darkspeed
Anyone know the Aluminum Alloy used for GMC 4106 skins?
It's all math and metal...
Boomer
Anodized aluminum with a special clear coat.  Don't know the alloy makeup.  If you remove the factory clear coat from the siding, beware; you will not be able to duplicate it.  BTDT with my Silverside.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
North Idaho USA
Utahclaimjumper
 2024T3 is the most commonly used in aviation for making panels of all sorts,,available at Aircraft Spruce.>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
Darkspeed
2024t3 is what I have used to repair / rebuild a number of airstreams from - https://www.airpartsinc.com/shopdisplayproducts.asp?id=28&cat=Aluminum+Sheet+%26+Coil.
The lower skins on my 4106, some PO took a disc sander to in areas and there is no way to re ano. it
my plan is to sand smooth and polish.
I have about 400hrs of aluminum polishing experience so i know what i am in for.
I polished a test spot on the bus and left it outside for a few months and so far so good.
I was just curious the purity of the alloy used in the 4106.
I sure wish the endcaps were aluminum on the 4106... but that is what gloss black is for i guess
I polish my 2024t3 airstream - about 5 hours - once a year and am very happy with it.
Bottom
