oil analysis
Started by Rube, April 21, 2006, 07:06:46 AM
Rube
how much oil do i need and who do I send it to for an oil anaysis?
thanks
kyle4501
Call your local DD dealer, they should be able to help.
You didn't ask, but for others who may not realize it, a single analysis won't tell much.
An analysis is just a tool, like a compression tester, exhaust analyzer, torque wrench, volt meter, etc.
A series of them at regular intervals along with the maint logs will provide much more information concerning engine health and potential problems.
I have heard that a coolant analysis can be usefull also.
Rube
so... since I am going to look a a bus in the very near future - getting a quart from the bus and sending it to a DD dealer for analysis will not give me insight as to the condition of the engine since I don't have a series of analysis's over a period of time? Hope that made sense.
pvcces
Rube, the analysis does a couple of different things.
Any given one give you a snapshot and it must be read that way.
Several snapshots in sequence will tell you a story that goes beyond what any single snapshot will.
A single snapshot will tell you a lot about what's NOT wrong.
For what it's worth.
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Suncatcher
Ketchikan, Alaska
kyle4501
A single analysis can tell you some things. But what if the oil was recently changed? What if it was used oil that was put back in to hide a big problem?
I would do the oil analysis, just be careful about reading too much into one snapshot.
If you can drive the bus, take it for a 30+ min ride (longer is better, or so I hear ;)) & put it on the hi-way before you take the sample.
just my $.02 worth,
Enjoy the trip to look at the bus, and remember, there are lots of good ones out there, so don't settle for a basket case.
akroyaleagle
DD has a kit that includes everything you need to do the analysis except the postage. They're about $16 for everything. The postage from Alaska is only a couple of dollars.
If you've never done this try it once and get your eyes opened. It cost less than 5 gallons of fuel.
Joe Laird
'78 Eagle
Sioux Falls, South Dakota
