6v92TA Thermostat Seal Tool?
Started by Seangie, December 11, 2012, 12:47:37 PM
Seangie
I have pulled my thermostat housing blocks, cleaned them up and painted them, pulled out the old thermostats (160's) and the seals and bought new thermostats (180's) to replace them.  The problem that I am having is that the seals inside the housing don't easily pop back in.  Is there a special tool to install these that I need or is there a secret unbeknownst to me to get these seals back into the blocks?
Thanks guys - Pics for reference -
'Cause you know we,
Driving through the night
To that old promised land'
Seangie
'Cause you know we,
Utahclaimjumper
 Are your OLD seals ("o" rings") square section or round like your picture seems to be??>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
Seangie
Dan,
The old seals are round and are exactly the same size/shape as the new seals.  The old seals were in tight.  I had to use a pair of locking pliers to pull them out.  I probably should have just left them in but I figured as long as I have everything apart and the new pieces, I might as well replace them.
I will probably end up taking the parts over to Covington/Clarke Power tomorrow as they should be able to seat them for me.  But still curious if there is a special tool needed or if there is a secret method (1/2" pipe and hammer) to getting these rings to sit correctly.
Thanks.
'Cause you know we,
Jriddle
I just did this job. I cut a 2x4 to fit. I then tapped the seal into place. Not to high tec. but it worked.
John Riddle
Townsend MT
1984 MC9
Utahclaimjumper
 coat each "O" ring with Dow Corning #4, a silicone based grease that lubricates neoprene seals and "O" rings,, also makes them last twice as long. Used extensivly in aviation for this purpose.>>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
72 VW Baja towed
  There is a special installer tool but you can take a old thermostat and install those also
oldmansax
I use a 1" drive socket to drive mine in. I forget what size it is though... maybe 2 15/16"...?? Just keep trying them until you find one the right size.   ;D
TOM
1995 Wanderlodge WB40 current
1985 Wanderlodge PT36
1990 Holiday Rambler
1982 Wanderlodge PT40
1972 MCI MC7
Did u get it? Btw why can't I see what utahclaimjumper is saying? His posts are blank?
Sent from iPhone via Tapatalk
RickB
I am with Tom on this one. I just used a large socket to get them in. Worked great.
RB
You guys do it with a 2x4 or a socket here I went and paid over a 100 bucks for the Kent/Moore tool lol but it works on Cummins or Cat also so all is not lost LOL
John316
Quote from: Scott Bennett on December 11, 2012, 04:54:50 PM
Scott,
Click the "unignore" button....Dan, I think I just found somebody who might be ignoring you. Check you stats right away ;D LOL
not trying to be a smart butt...but when those seal bores were new they were a whole lot shinier....clean um up and put um in !!  ;D
oldmansax
Quote from: luvrbus on December 11, 2012, 05:51:39 PM
The "special service tool" is probably cheaper than a 3" socket!! LOL! Besides, us country boys got to make do with whatever!   ;D ;D
TOM
1972 MCI MC7
wg4t50
Understand , here I just grab the correct socket and bingo, no idea of the size, but I have the right one ;D
No biggie deal, you can install it IF you have some experience using a hammer and extension, say a 1/2" or 3/4" (most anything) either would work fine, just tap it down to correct point, make sure it is straight in the bore.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
